Brake warning light
MUDHUNTER
Jun 14, 2022
Has anyone had a issue with the brake warning light coming on at highway speeds. Cruising at 100-110 k/hr and the light randomly comes on. Brake pedal becomes hard, have to push hard as if it is stuck. But a key cycle and it goes away.
If 2.3l, then yes. Vacuum tube/sensor was bad on mine, causing loss of vacuum boost. Seems like a known issue with the 2.3.
https://thebronconation.com/forums/threads/bronco-brakes-failed-known-issue.8310/
Deano Bronc, ChuckO
Jun 14, 2022
Yes take it in. If it is the vacuum line like @Shoresy and you have to make a hard brake maneuver on the highway it might be really hard to push the brake pedal hard enough to stop in time.
Hello! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this brake warning light concern. Thanks!
