Tires???
RMoran522
Sep 11, 2021
Good evening folks! I need some help. I want to change out my tires which are Continentals and upgrade to a better and more aggressive one. I don't what to do a lift nor change the size ( 225 65 17). I also don't what to sacrifice speed rate or mileage. FYI, I'm getting 30.3 mpg. Any suggestions??
Thanks,
Ron
Sep 11, 2021
Thanks,
Ron
I suggest you keep you Continentals
Bronco1984, SlashRacer
I’ve had good experience with BFG KO2’s
AmCap76, Bronco V-8
Sep 11, 2021
never mind
4 Door Badlands: Carbonized Gray, 2.7 Eco, Sasquatch Package, Towing Package, 35" Tires ETC
Khayze427
For a Bronco Sport, I'd stick with a "C" rated tire, or P, whatever is stock. A 10-ply/E rated tire will likely diminish ride quality.
Khayze427
Sep 13, 2021
Big time we had 8 ply on a 250.First thing in the morning they were rough until the flat spots rolled out.
Khayze427, AcesandEights
Gosh it's hot
Sep 13, 2021
Thanks,
Ron
The more aggressive the tread design the lower the mileage. There's no way around that. A standard highway tire has lower rolling resistance, therefore smoother ride and better mileage. If you move to an all-terrain tread choose something with a continuous center rib, this will help with the mileage. Also, if the door jamb states 32psi (for example) you can increase that a couple of pounds and it will also help to decrease rolling resistance.
Black Diamond/4-door/mid pkg/2.7/MIC/rack/towing/Eruption Green/res 7.13.20/ord 2.8.21, then 10.15.21/built 1.21.22/delivered 4.15.22
Gunstock Off-Roadeo 10/29/22/Steel and Stirrups Traveling Lamp holder 9.23
Gaia GPS
heavy duty lifting
the Asphalt treads
I prefer the TSL SXII, but they might be a bit much on a Bronco Sport :)
Munky
Oh crap did I find my way onto the sport side….
however nice to see a fellow InterCo fan, there was a 99 Cherokee I was very fond of that wore a set of the original TSL. Oh god those poor rice fields……
AcesandEights
I have always liked the Nitto terra grappler 2 tires. I have them on my F350 and never had an issue.
Bronco Badlands, Bronco Black Diamond, Bronco Big Bend, & Bronco Sport Badlands
www.youtube.com/1five1garage
Sep 13, 2021
Here comes the tire debate.
AcesandEights, 1Five1 Garage
Thanks for all of your replies folks! I ended up getting a set of Michelin Defenders. I stayed with the same size and wheel and gave the Continentals to my daughter inlaw . They only had 6k on them. Bottom line is we're all happy!! LOL
Ditchrunner
