Swing gate ajar light on
Toointense
May 05, 2022
2022 Badlands - The Swing Gate Ajar light stays on. If I push OK on the steering wheel it goes off, but there is still a little red icon showing up on the dash. Suggestion on why that is happening? How to fix or bypass?
Maybe push the sensor in the jamb of the tailgate or on the tailgate itself (not sure where the sensor is located) when its opened and if it doesn't light up anymore on dash then its bad contact between the tailgate and sensor. If it stays lit up on dash when you push the sensor, then you might have a bad tailgate door sensor.
2021Bronco☆2.3☆BL☆7MT☆4D☆A51☆SoftT☆ARRIVED 9/9/21☆SOLD 1/21/23☆NT Supports▪Consults▪Supply's Car Dealers, Vehicle Distributors, and Retail Customers Since 1992
907Ford
Thanks, I’ll check that out. I’m sure it has to b a simple fix
NT AUTOMOTIVE
May 05, 2022
Do they have a push pin sensor on the Bronco? my old ‘04 F250 doesn’t have these.
Open the back gate, look all around (hinge and latch sides) for any obstructions, close the gate. If it still comes on, I'd get the dealer to check it out. Too new to be fixing yourself.
7/14/20 Res, took delivery 4/7/22!!
A51 2 door Badlands, 2.7L, Sasquatch, Lux, MGV, MIC, Roof Rails, Tow
Jakob1972
I'll take a close look... Thanks
Did you get a resolution to this?
No. Goin to take to dealership to figure out
Same problem here with 'swing gate ajar' light. Wouldn't extinguish, took it to the dealer and they said it was a bad power source to one of the pins, they ordered a new part and I'm due to have it installed in 4 days. I'll post an update as to how it all shakes out.
Additionally it appears I lost my parking assist lines coincident with the 'swing gate ajar' light, and I'm hoping that this resolves it...
Laura
Thanks. Keep us updated. I live about an hour away from my dealership. I haven’t had time to take it to them yet
Issue resolved. They removed tailgate latch cover and checked power at pin 3 (swing gate ajar circuit) to find 12v. Replaced tailgate latch per workbook procedure, problem resolved.
Additionally, with the ‘swing gate ajar’ light, I had lost my reverse lane assist lines, the fix also resolved the latter problem.
Issue covered under warranty.
KennyMac, BigBender
