Rear seat delete platform/ floor mat options
Broncadonk MKG
Jan 31, 2021
Has anyone seen chatter on social media from companies like Goose Gear about rear seat delete mats and platforms?
I think I’ll really just want a rubber or vinyl floor mat in my BD, not a platform. If I end up with a platform, I think I’m just going to build one myself instead of buying $1000+ worth of pre-drilled painted plywood.
Pakrat
Who's your daddy?
Feb 01, 2021
I'm doing the same thing, I want to take out the seats and replace carpet with a mat, maybe by time I buy it it will be an option.(y)
If make my own I'll do a platform it will have a slide out surface big enough to sleep on.No plywood, I have a CNC plasma cutter at my disposal.:devilish:
Bschurr, KennyMac
I am getting the BD so it already has the washout floors. With that in mind I’d prefer to keep it washout capable, which would bump up expenses if I have to have a washout capable platform. That’s why I’m hoping someone’s already planning a molded vinyl or rubber mat to cover up and smooth out the seat holes so there’s a flat surface. If someone designed a mat that has plugs that pop into the pre existing holes so the mat stays put, they’d make a lot of money.
Jakob1972
Who's your daddy?
Feb 01, 2021
Rubber mat with duckbill valves in the center of the plug that holds it would be cool.
Broncadonk MKG
Even with the rear seats removed there is a raised seat mount extrusion across with exposed bolts/studs. Might have to cutoff the bolts/studs. Don’t know if the raised extrusion is structural, or just there for the seats.
Broncadonk MKG
Who's your daddy?
Feb 01, 2021
I plan on using that to anchor my slide out sleep platform.
Thane
That’s a good idea. Aftermarket or build your own?
Who's your daddy?
Feb 02, 2021
Probably build my own.
Khayze427
