I am installing the rear cargo drawer and it leaves a rather unsightly gap. I am wondering if anyone has dealt with it to cover/hide it and what you did. Looking for ideas
T
TBoneBronc
August 12, 2021
53
83
1356
3368
Dec 11, 2021
I am thinking that you could cut a small plate out of plastic or metal (painted) with holes to accommodate both the bolt that mounts the drawer and one in front for a bolt to hold the plate in place. You could use a button head cap screw style that wouldn't have any rough edges (it is domed like a carriage bolt with an Allen Key hex in the middle of it). Here is a good link to all sorts of screws and other hardware: McMaster screws
They had the same issue on the demo unit at the Austin OffRoadeo
MIGeezer
December 06, 2021
1975
2600
2656
90999
Dec 11, 2021
With the drawer installed how do you get to the storage area under the floor? It looks like you removed the floor hooks and this attaches in those screw holes?
If I remember correctly you have to remove the drawer which then give access to jack storage area.
_jeff, ResidualGenius
WyldFire
Slownstddy
October 07, 2020
1555
3387
4080
1508
Dec 11, 2021
If you kept the piece of "dunnage" plat that came with it, you could cut small pices and drill a hole and bolt it down to cover that. Im going to try that today.
I am thinking that you could cut a small plate out of plastic or metal (painted) with holes to accommodate both the bolt that mounts the drawer and one in front for a bolt to hold the plate in place. You could use a button head cap screw style that wouldn't have any rough edges (it is domed like a carriage bolt with an Allen Key hex in the middle of it).View attachment 23493 Here is a good link to all sorts of screws and other hardware: McMaster screws
dsnow58
July 07, 2020
75
116
1625
100123
Dec 12, 2021
I am working up a 3D model of the cargo hook cover that was there before and then I’ll 3D print black plastic covers that have a slot in them to cover the painted area and fit snugly around the screw. Just working on it in my free time so it may be a month before I finish it, but will gladly share the file when I’m done and could print extras for people if they want them.
Scarydog, nic
Scarydog
September 09, 2021
35
71
1059
3584
Dec 12, 2021
Cut some 1/4”MDF to fit and covered with a little of the outdoor carpet from the back of the drawer.
