How to Use Sync 4 in the 2021 Ford Bronco
Jun 29, 2021
By Laura Zielinski
Join us as Mitch from Town and Country TV takes the Bronco Nation through the ins and outs of the Sync 4 infotainment system on the 2021 Ford Bronco. He’s using a Badlands with the Lux package to demonstrate, which means this Bronco has the 12” touchscreen.
What is Sync 4 and what does it do? Sync 4 is Ford’s information and communications system. Use it to do things like navigate, access your apps and owner’s manual, and control your music and zone lighting.
Start by pairing your phone. Go into your phone’s Bluetooth settings. Then, on your infotainment screen, tap phone > add a phone. Back on your phone, find your Bronco in the list and click on it. A pin number will appear on both your phone screen and the Bronco’s. Hit yes, and pair. There are some further prompts, like pairing contacts as well as enabling the always-subscription-free 911 Assist and CarPlay to wirelessly cast apps.
To use the system, you have several options. First, the menu that runs along the bottom of the holds navigation tabs to audio, CarPlay, the navigation system, apps, settings, and features. Second, on the right side of the screen, you can access features through scrollable cards. Finally, you can also use the voice command button on your steering wheel to control your system.
KenDawg78, Bronc96
The wife will be home from work any minute. I'm hiding in the closet with the lights off watching this one...
7/14/20 Res, took delivery 4/7/22!!
A51 2 door Badlands, 2.7L, Sasquatch, Lux, MGV, MIC, Roof Rails, Tow
Bronc96, Jakob1972
So on the "cards" on the right side, when you pick fuel economy, is that a running 50 mile avg, trip odo, since last start...?
Jul 01, 2021
Is there another way to feed it music files without using your phone? found the answer thanks now for the million dollar question, if you put a thumb drive in the dashboard, will it stay there on a washboard road? does the drive have to stay there or does it load to a file?
never used synch and hate it already
