Help! Leaking coolant from a cap on engine block
jgarcia818
Jun 04, 2021
Hello everyone, so all of a sudden my Bronco started leaking coolant from a metal cap on the engine block. The metal cap is located above the oil pan, right next to the base of the oil dipstick. The metal cap looks like its indented into the body and appears not to have any threads of any sort to come out. Not sure, how to fix it or what the name of the cap is, or how to approach this issue. Any ideas would greatly help. Thank you!
Member 2541 Jerry
Jun 04, 2021
Looks like a feeze plug
2022 -2door Black Diamond
Mid Package
2.7. Velocity Blue.
GDavis
Perfect, thats the keyword i was looking for. THANK YOU!
14U
Member 2541 Jerry
Jun 04, 2021
If it is ,
Likely installed damaged
Mid Package
2.7. Velocity Blue.
If it is ,
Never been replaced. its the stock one
14U
Member 2541 Jerry
Jun 04, 2021
Old Bronco , likely corrosion/rust has compromised the seal.
New Bronco, likely not in fully flat or damaged during installation.
Mid Package
2.7. Velocity Blue.
Jun 04, 2021
Of course the dipstick and exhaust pipe is in the way of replacing it. Murphy's Law is victorious again! :rolleyes:
KennyMac, Howdy
Yeah, its a 1995 so im sure time got the best of it. Thank you so much i really appreciate it. You sure guided me in the right direction.
absmith0, PSUTE
Member 2541 Jerry
Jun 04, 2021
where are my manners ...
Welcome to the Bronco Nation !
Mid Package
2.7. Velocity Blue.
absmith0, Howdy
Jun 04, 2021
Make sure it comes out, if it ends up in water jacket, get it out. Freeze plugs leaning against cylinders create hot spots and can lead to cracked cylinders.
KennyMac, Howdy
Thank you very much :)
Thanks for the tip @Bronco5.0
14U
Rank XII
Jun 04, 2021
Oh yeah Welcome to the Bronco Nation.
Howdy
Rank XII
Jun 04, 2021
....and @jgarcia818, I could learn some manners from @14U and @Bronco5.0 too....Welcome to Bronco Nation, my friend!
