CB radio and antenna suggestions
willienme
Apr 23, 2021
What is the best radio and type antenna / mount for the Bronco?
Home, home on the range
Apr 23, 2021
There is a thread called "What communications" that would probably be helpful.
2022 Bronco Black Diamond 2dr 2.3L manual Hot Pepper Red. Reserved 8/7/20. Ordered 1/23/21. Reordered 10/08/21. Scheduled week of January 24th 2022, delivered 2/24/2022
TK1215, Rgwinn
OBXBroncoGuy
Apr 23, 2021
Well, its a little helpful with a lot of info about every communication there is :LOL:
I think the op just wanted to focus on the cb part and cut the rest out :cool:
I have no other help than that, sorry
SlashRacer, TK1215
Apr 23, 2021
Well I did say probably ;)
I was thinking about getting a CB but after reading the post I earlier mentioned I'm not sure if that's the way to go.
TK1215, Bschurr
A CB is like getting the Motorola Startac cell phone today LOL
Go for an FRS or GMRS radio
TK1215, Bschurr
OBXBroncoGuy
Apr 23, 2021
That’s a 10-4 good buddy..nah, give me old skool
TK1215, 14U
10-6
Some organized groups & clubs are still all Citizens Band. Others are moving or have moved to GMRS - FRS. Depends on who you expect to talk to. Probably need both for a while.
Apr 24, 2021
I'm not sure it matters what type or brand. It comes down to personal preference and how much you want to spend. There should be a bracket available to mount an antenna to the trail sight, or I'm sure the aftermarket will come up with a solution for mounting one on the roof, roof rack, or rear bumper/spare tire carrier. The most important part is to check the antenna tuning with an SWR meter after installation, and adjust if necessary to avoid creating excess noise, prevent radio burn-out, and increase range.
TK1215, Rexen
I got my license and picked up a couple of GMRS handheld radios. Used them on a recent trip with the family and they were outstanding. Am looking forward to picking up a higher wattage base unit for the Bronco!
BuzzyBud, TK1215
OBXBroncoGuy
Apr 24, 2021
Show me 10-42 for beers LOL
TK1215, Rexen
Apr 24, 2021
Using standard 1979 circa logic you need the radio with the most buttons, knobs and switches with the longest antenna you can find. This works out to the
Cobra 29LTD with built in SWR and a 102" whip.Radio is only 120 at Amazon.
I would get a CB over anything else unless you are in a group with others on the other radio choices.(GMRS - FRS) Just kidding on the antenna get a loaded antenna, most are magnetic mount so mounting on roof might be a challenge.You could bolt a piece of steel to the roof stick the antenna on it.
Soggy, 14U
Cobras are good. I have a Galaxy DX-959 that pretty much covers the 11m band. Good rejection, good modulation ETC.
4 Door Badlands: Carbonized Gray, 2.7 Eco, Sasquatch Package, Towing Package, 35" Tires ETC
Cb is where its at for me. I'm gonna try a magnet mount on the roof but might switch it to a glass mount. Not sure which way will work best...
CBs are 10-7.
You'll want to pick up a solid GMRS unit. 2.1 or 3dbi antenna for hills/mountains/city. 6 to 9dbi for the flat wide open/prairie areas.
Curious where are you using the magnet on the MIC roof??
Oh sorry, should have said I have a Bronco Sport. Going to place it near the back. Hoping there is no SWR being close to my roof basket.
14U, TK1215
I know a J**p owner who glued a thin steel plate to his roof as a good solution on how to use his magnet mount antenna. It worked well on trail rides.
TK1215, Rexen
Liquid Nails would work perfectly for that
14U, TK1215
