Bronco's RPM's @70mph for each series.
Nov 11, 2020
Nov 11, 2020
I keep hearing how the 4.7 gearing for the manual Badlands and the Sasquatch package is going to cause fairly high RPM's when driving down the highway.
I made all my calculations from this link - RPM Calculator
The final transmission ratio for the manual is .646:1 and the auto is .636:1 if you want to play around with different sized tires and rear gear.
It looks like the manual base cruises at the highest RPM and the auto Big Bend and Outerbanks with the 3.73's have the lowest RPMs.
The Sasquatch isn't too bad when compared to other series but of course gas mileage will be hurt due to extra weight and width of the 35's.
I hope someone finds this useful as I found it interesting. Please let me know if I forgot a combination.
Soupcook, BroncoBill
Nov 11, 2020
Very helpfully indeed. Thanks for posting
Defeated by Mickey’s Hot Tub
Nov 11, 2020
Who drives 70mph? :unsure: More like 78mph. ;)
2021 Badlands, 4 door, 2.7L, Auto, LUX, SAS, Tow Package, MIC, Velocity Blue.
Rusty Shackleford, johndeerefarmer
Thanks for Posting! We here in Texas drive in the 80's. Run Wild right? lol
TXArchitect - 1719
[O=BRONCO=O]
BeardsBeer&Broncos, Jakob1972
Nov 11, 2020
Well, you all have school zones don't ya? :LOL:
Gutter Clown, Smoothmove
Nov 11, 2020
What are those?!?! :ROFLMAO:
Rusty Shackleford, Speed Devil
I ordered an FE Bronco Sport in Cyber Orange. I will look just like the other buses and disappear. :eek:
TXArchitect - 1719
[O=BRONCO=O]
Great job! Black diamond sticks out. Fairly significant increase in the automatic RPMs. My question is how the 2.3 will perform with the automatic given the low RPM. With only 310 ft-lbs of torque I hope it doesn’t continually downshift at highway speeds.
Jakob1972, SlashRacer
Great info Deano, thanks for crunching the numbers and posting! Not as bad as my 96 with E4OD and 4.10s, however appears my new Mansquatch won't have too much top end for road trips but that is the sacrifice for having the low end grunt. :p
Nov 11, 2020
I had to laugh, it is funny how we are now talking about cars with only 310 ft-lbs of torque. I want to say my old F250 only had 400 ft-lbs and it was a torque beast and had to move around a CCSB 4x4 superduty not a midsize SUV.
ChetC, Bronc96
I did this for the Badlands, 2.3 and 7-speed with 33’s and 4.7 rear. Based the red/yellow/green bin the Ranger stock 2.3 dyno curves.
Based on this, I think quick passed, on the highway will warrant a downshift from 7, just where the Ranger dyno numbers land. The double overdrive and possibly a slightly different tune may help. 3k RPM looks to be where the boost really comes in so cruising should get decent MPG.
JFord, Jakob1972
Well, found one of my Featured User Threads for the week.
Hobgoblin, Level3Looper
Nov 12, 2020
Great chart!
It's amazing that you would be going a little less than 10mph at 3000rpms when using the rock crawler gear.
Bronc96, SlashRacer
Great chart!
Way back I was friends with a guy that raced (and still races) KOH. His original theory was being able to run a lower gear in the T-case (3-speed) and still be able to hit 120mph across the lakebed. The basis was at a 2:1 or less, he had that much more torque available. Same applies to the Bronco. My chart is just with the T-case in high range. Low range will be a BEAST.
TK1215, Deano Bronc
Nov 12, 2020
Wow, I hadn't even thought about low range. You would be just barely moving when the motor is in it's peak torque range.
Do you have a dyno sheet available to post for the 2.3?
TK1215, SlashRacer
This is with the 10 spd and rear wheel numbers. Link to the article if you want it too.
https://www.fordf150blog.com/2019-ford-ranger-dyno-chart-2-3l-ecoboost/
TK1215, Deano Bronc
I believe that's the one I used. Basically looked at where torque started to peak, indicating the turbo spooling up and MPG subsequently dropping.
Deano Bronc, JFord
Feb 06, 2021
Those are the school zones!
Your unofficial Favorite Author
Jul 14, 2021
So basically:
2dr Badlands 2.3 Manual w/Mid, Rapid Red
My blog, Mfcomics.net, my stories: https://payhip.com/MFComics
Rusty Shackleford, Jakob1972
I was not expecting to find so many speed heads on a Bronco forum.... I am PLEASANTLY surprised. I am home.
Deano Bronc, Speed Devil
