I laughed at the Motor Trend article because it was either just written lazily, or it was slanted towards the Jeep.
Saying this right away turned me off, because that isn't the reality of the process for the Jeep.
, the process takes longer and requires more steps than simply pulling the Jeep's transfer case shifter into gear and hitting the nearby locker and sway buttons.
Every driving experience I've had or seen with the Jeep, getting the transfer case to shift isn't just as simple as doing it, nor are getting the lockers engaged.
I found the Car And Driver to be fairer and is likely more representative of what most people who buy these vehicles will experience. The majority of Bronco owners will not be going off-road that much. You get penalized for that more in a Wrangler than a Bronco.
That said, at least Motor Trend got one thing true at the start of the article.
We'll get to things like ride and handling and interior and all that, but we need to answer the most important question first: Which is the better off-roader?
Car And Driver didn't really attack that question very well. Personally, I would tend to say it depends on where you want to go. Narrow rocky areas, an appropriately outfit Wranger will handle that with less rubbing. You can only match the view you get in a Wrangler by using the camera technology of the Bronco, but that only comes with specific packages. The Wrangler maintains that ability to see around the front and sides regardless of tech. But dirt roads, fire roads, sand, through the woods or even a rocky area with a spotter, I would give it to appropriately outfit Bronco.
2D Base Mansquatch: Ord 11-24-2021; VIN 3-16-2022; Schd 5/9/22; Sticker 5/4/22; Modules 5/10/22;Built 5/11/22;Shipt 5/12/22;Delv 5/24/22
