Dec 14, 2020
This is the Q&A thread for the week of 14 DEC 2020. Please post your questions about the 2021 Ford Bronco here.
Questions that have already been asked and have been added to the question bank can be found in this thread: https://community.thebronconation.com/forums/threads/bronco-weekly-q-a-for-week-of-07-dec-2020.2541/
Update on the question poll from last week:
Questions are still with Ford. We are also looking at some ways of moving beyond just 5 questions a week. Understand that this Q&A process will evolve but our central goal is remaining the same: provide a reliable channel of communication between Ford and the Bronco community.
Q&A Video with Bronco Brand Manager, Esteban Plaza-Jennings
Answered Questions from Last Week:
Question | Answer |
Manual sasquatch is still not in the B&P, what gives? | Sasquatch on manual transmission Broncos has been pushed to the 2022 MY. |
Any manual lumbar adjustment on seat? | Both powered and manual seats have lumbar adjustments. |
Is the B&P accurate with no manual and Squatch combo on the Base even as late availability? States can't pair Advanced 4x4 with manual on Base? | Advanced 4x4 is available on Base as part of the Sasquatch Package. The Sasquatch Package requires an Automatic transmission until the 22MY. |
What date will we be able to convert our reservations to orders? | Mid January |
Will the electrical and washer connections for the hard top be included if only a soft top is ordered? | No only hard top, and the late availability dual top trucks will have those connections. |
The Bronco used for the second how to video, did that have the headliner or not? | It did not have the sound deadening headliner. |
Have we heard the rating on the 12V outlets? Also, are they two prong or three? | There is a 150 Watt plug that comes as part of the Mid Package with three prongs, and the fuse is rated to 40 A. The 12V auxillary power points have fuses rated to 20 A. When you switch the Bronco on, you can use the socket to power 12 V appliances with a maximum current rating of 20 A. Ford doesn't recommend using the power point over the vehicle capacity of 12 V DC 240 W or a fuse could blow. In total, the Bronco provides 400 watts when in park and up to 300 watts when in drive mode. This wattage is divided between multiple outlets when in use at the same time. |
What's up with no soft-top for two door Broncos? | There will be a dealer installed accessory soft top that will be available for order at launch. It's made by Bestop and will be a full weather tight top. |
The four-door Bronco's length is listed at 189". Does that include the spare tire protrusion past the rear bumper? | 189.4 inches includes the spare tire. |
LED tail lights...Available with Outer Banks and up trim levels only or will they be a part of the signature lighting on the Big Bend? | LED taillights come standard on Outer Banks, Badlands, Wildtrack, and First Edition. LED taillights are a part of the Signature Lighting option that is available on Big Bend. |
Will we be able to order the Advanced 4x4 System on the Base and Big Bend models without the Sasquatch package? | No. |
Will the electrical connections for a hardtop be pre-installed on a Bronco ordered with a soft top? Or, will this need to be added separately? | No, they will not. |
Gunninja1, BroncoBoy22
