Ambient air temp went crazy, now no reading
Bluebend
Feb 26, 2022
Today while driving home my outside temp reading started climbing, all the way up to 176 degrees then failed, now display just reads dashes. Check engine popped on, P0072 ambient temp circuit code. Can't find sensor location. Anyone familiar?
BroncOitis
Bill - Enjoy The Journey
Feb 27, 2022
I’m guessing the sensor came loose and a) it’s either reading a location near the engine or b) it’s a loose pin at the sensor and it simply went to its max limits. It’s occasionally been that hot here in Arizona (hah) but wouldn’t imagine that’s your case.
I don’t know the exact location in my yet to be built Bronco but Ford typically seats them in the lower grill / bumper area. At least that’s the case on my Super Duty.Keep us posted.
‘22 Cactus Gray / Badlands / Sasquatch / LUX / Leather / MIC
BroncOitis
Team Jeff!!
Feb 27, 2022
Interesting, another BN Member had the same issue today!
Other thread
BroncOitis
“Step outside, Take a deep breath, Get real high”
Feb 27, 2022
Most temp sensors are just above the bumper or right around the grille area. Hopefully it's just a bad sensor. That's what a Warranty is for. We can only hope that all the problems show them selves before the warranty runs out.
*632* Days to get A 2021 - 2022 -
2023 Big Bend - 2 Door 2.3L Velocity Blue, Squatched, Mid package, Running Boards, Roof Rack, and Engine Block heater.
Negative to previous responses. Bronco sensor is under driver mirror little square with like a tooth pick tip sticking out. It has failed like mine and many others recall coming soon. You can disconnect your door cable to the body to check connection but will tell you it has failed. No connection issues have remedied. Call your dealer and get on the list of fails. It will screw with your hvac till you see the dashes after running a while then can control your heat like normal. To get heat you to crank dial to max heat and turn it off and on to regulate till fixed
Is it part of complete mirror assy or is it serviceable? Did it take long to get part?
Feb 27, 2022
Good to know. Appreciate the update and education. Different than other Fords in my garage.
Still waiting to get fixed. Appears to have separating clip will try tomorrow. But have heard others on 6g entire mirror replacement
mine failed in five weeks and 3200 miles many others all have failed very early. I imagine this will be a wide spread issue and a design issue With thermal dissipation of the circuit as from people with issues are from cold climates primarily.
