2023 Ford Bronco Raptor
Deepshag
Sep 09, 2020
Wank ER
Sep 09, 2020
https://fordauthority.com/2020/09/2023-ford-bronco-raptor-spied-testing-for-the-very-first-time/
Well, well, well....let's add more anxiety to the Bronco decision makers. Looks "burley".
"Up front, the Bronco Raptor will feature a revised front fascia, with a unique bumper treatment. Being the ultimate expression of the new Bronco family, the off-roader will also have noticeably higher ground clearance with a wider stance compared to even the most range-topping Wildtrak model. That added width will be wrapped in significantly larger and more pronounced fenders hiding a set of wheels that will have a resemblance to the units used on the F-150 Raptor.
The rear end of the 2023 Ford Bronco Raptor will follow along in the footsteps of the front, bringing a revised rear fascia with a different bumper treatment. A single-exit, dual-tip exhaust located on the driver’s side of the SUV will handle the exhaust duties.
Those closely following the Bronco may have already expected some, if not all of these features. What’s surprising is that our sources tell us that the Bronco Raptor might end up wearing headlights and/or tail lights that will be unique to the model. Under the hood will reside Ford’s twin-turbocharged 3.0L EcoBoost V6 mated to the 10-speed automatic transmission. No manual is currently planned. A hybrid might be offered later on in the model’s lifecycle. Additionally, a set of thorough chassis and suspension upgrades – which we will outline shortly – will be present and accounted for under the bones. "
https://fordauthority.com/2020/09/2023-ford-bronco-raptor-here-are-our-exclusive-details/
2021 FE Cactus Grey
Broncofly, Deano Bronc
No manual planned is kinda sad. But super suprising as the Raptor doesn't have one either. It would be nice however.
Sep 13, 2020
"No manual is currently planned. "
They are moving in the right direction displacement wise, now they just have to add a couple more cylinders.;)
JFord
The silver lining is there.
Now all we need is a NA v12 2 door bronco manual.
