Jan 23, 2022
There are many videos from vendors and others on the oil change process. I will try not to rehash any of that, but I did learn something changing oil on 2.3L Badlands.
It does seem little tricky to get to the oil filter. Picked up a filter socket for $7 and can easily access through the wheel well! And whoever invented the filter drain “chute” deserves a Grand Award!
Here’s my wrench setup.
Put the socket (76mm, 14 flute) and U-joint on first then attach the extension and ratchet. Place your drain at the end of the chute and loosen the filter a couple turns until oil starts flowing. Then just wait until it stops to remove the filter (I went back under the car for this). Didn’t spill a drop of oil!
615_Bronco, Corncob
