Wood steering wheel...
SI HRSE
Nov 24, 2020
Where did you buy/maker? Easy to install?
First your post is a bit confusing with the pic you posted. Is that your Bronco and the wheel you're going to replace?
Anyway, Tom's Bronco Parts has a great selection of aftermarket steering wheels, as do most of the early Bronco Vendors. But Tom's kind of known for their steering wheels and nice interior parts. Tom's Wood Wheel
Also you can find them on Ebay or through Amazon.
Just need to buy the correct adapter and they are easy to install. Getting the old one off is probably the hardest part. You'll need a steering wheel puller.
2022 Bronco BadSquatch, 1974 Bronco Ranger, 1976 Bronco Crawler, 1978 Bronco Custom
Yep! Replacing steering in image with wood. Color to match shifter knobs.
That one is in my cart at Toms
Looks like it comes with adapter. $179 is a great deal from what ive seen so far.
How do you know if you need a 9 or 6 screw wheel?
Not sure what the 6 or 9 refers to. A single nut holds the adapter to the splined steering shaft. The adapter normally has 3 bolts to hold on the wheel to the adapter. My guess is this is to do with the center trim ring and horn button. Again my guess is the 6 or 9 doesn't matter - whatever the aftermarket wheel has should be OK. Someone correct me if I'm missing something here!
Nov 25, 2020
Nice Bronco, that wood wheel will really set it off.
But what car is that in the picture?
Sounds correct to me... my adaptor has six holes mounting the steering wheel.
Is it heated?... :D ...
'21 AMB Basesquatch 2 Door. 2.7. 569 days from reservation to delivery
SI HRSE, Deano Bronc
Dec 13, 2020
All done. Looks good!
Very nice! Matches well with the shift knobs.
