What's going on your AUX switches?
What accessories are you hooking up to your AUX switches?
  • Pod Lights
    Votes: 60 75.0%
  • Fridge
    Votes: 19 23.8%
  • Air Compressor
    Votes: 28 35.0%
  • Light Bar
    Votes: 50 62.5%
  • Other (let us know below)
    Votes: 24 30.0%
  • Total voters
    80
Staff member
Super Moderator
Promoter II
Mar 19, 2020
1,608
8,975
Southgate, MI, USA
Liebmann
144
Reactions: Slownstddy
Deepshag
Jul 13, 2020
423
1,088
1,713
Caliunicornia
Shag
Hughes
I am placing: compressor, pods, light bar, rock lights, "upstairs" power for roof tent, rear detach flood light
Reactions: David
BuzzyBud
Aug 7, 2020
1,746
7,239
USA
Warren
Parlee
0884
OK, now the fun begins! My tentative list is:
Circuit B1 = GMRS Radio
Circuit B2 = Pod Lights
Circuit 3 = Fog Lights
Circuit D = Camp lights installed on the parameter of Yakima Roof Rack.
Circuit E = Trail chase light installed at license plate holder.
Rhiostatic
Supporter I
Dec 21, 2020
106
335
1,605
Phoenixville, PA
Erik
Johnson
2185
Yeah this, I have been following your posts and love the 400 GMRS you talked about. I wont have the roof rack like you but I will be getting chase lights, learned my lesson on my truck in the dark. Pod and Fog lights are also a must. Dear and snow
BuzzyBud
Aug 7, 2020
1,746
7,239
USA
Warren
Parlee
0884
Forgive my ignorance, but I understand we have five circuits and six switches. That assumes we can connect two separate devices within one of our circuits. So, in my case circuit, 3 could have both fog lights and a winch using two different switches? They would also connect to different places in the Power Distribution Box. I guess I may have missed that two wires are running to circuit 3. Got to rewatch the video. Does that make sense?
Hobgoblin
Champion III
Jul 29, 2020
504
1,638
2,964
Milton, Georgia
MATT
HOBBS
0811
Will be going with Baja Designs lights and likely a winch. Will be reading all, your additions to help decide the rest!
BuzzyBud
Aug 7, 2020
1,746
7,239
USA
Warren
Parlee
0884
The diagram prepared by @swooshdave is brilliant! See attached below.
Now we can see more clearly how Ford has given us three circuits that are prewired back to the power box. They are B1, B2, and C. You can always use circuits D and/or E, but in doing so you use up B1 and/or B2.
I like how this design is way more than most buyers will ever use. Big thank you to Ford!
I also like how this requires careful thought as to how circuits will be used. You would be wise to separate in your mind the “need to have” versus “nice to have” gear and the preferred placement of each. Finally, will be the amps needed for each device, so you know where to connect in the power box.
With this new vision in mind, my plan has changed as outlined below.
Circuit B2 = TBD, either passenger compartment air compressor or link into Circuit E for rear chase light.
Circuit C = Fog lights.
Circuit D = No plans to use currently.
New Circuit F = Pod lights.
New Circuit G = Winch
New Circuit H = TBD, air compressor in the engine compartment.
This revised plan requires that I hold off using Circuit B2 and Circuit E until the air compressor location is determined.
In this revised plan, I may not have a rear chase light via Circuit E since the air compressor would need circuit B2 and perhaps Circuit E. In that case, I will explore using the new circuit H for a low-mounted light bar on the front bumper.
Lots of options and no limitations. Nice, real nice!
BroncoPA65
Super Supporter II
Jan 24, 2021
49
131
1,059
Lehigh Valley, USA
S
M
2126
It will definitely take some thought and planning, but the pre-wiring and routing is a great feature. I'm assuming (obviously) that this (or other) diagrams and additional hookup/configuration details will be in the Owner's Manual... Being an engineer, I'll want to read through that documentation before finalizing anything just to make sure I'm configuring it the best way possible for the power budget and accessories yet to be picked...
I like your selections starting point so far though!
BuzzyBud
Aug 7, 2020
1,746
7,239
USA
Warren
Parlee
0884
I suspect each owner will align their electrical plans to how they use their Broncos. For me, it is all about camping. Since I plan to utilize a camper/trailer, the fridge will be in the trailer. Camp lighting will be there as well.
I love the idea of not having to run wires through the firewall or drill holes in the body. So, a roof-mounted light bar is not on my list of required gear. I think if I were into high-speed nighttime travel, a high mounted light bar would be essential.
If anything, this new knowledge has focused attention on dependencies and priorities. Over time we will learn what others are thinking, but at least now I have a starting point for moving forward. Nice!
Slownstddy
Oct 7, 2020
553
1,158
2,964
Riddleton, TN, USA
Michael
Taylor
1508
@BuzzyBud - "You would be wise to separate in your mind the “need to have” versus “nice to have” gear and the preferred placement of each. Finally, will be the amps needed for each device, so you know where to connect in the power box"
This is my whole issue with this. I love that thier setup, but feel i need a masters in electronic engineering to figure this out. Sorry I'm so simple minded when it comes to amp wiregauge calculations. I have a bit of an A type personality and want it to be done right but will constantly worry if im going to burn someting out or catch fire. Sorry I'm rambling like rainman now....
So, the single wiring is good throughout for 25 amp and have to connect 2 for 50 amp(for compressor, fridge..etc)? What's the amperage output at the individual power distribution points?
Reactions: BuzzyBud
Slownstddy
Oct 7, 2020
553
1,158
2,964
Riddleton, TN, USA
Michael
Taylor
1508
Im thinking of connecton power busses to each power point to make swapping stuff out easier. Connectors are nice but bieng able to just put an eye on a wire and connect it seems simpler
Reactions: BuzzyBud
BuzzyBud
Aug 7, 2020
1,746
7,239
USA
Warren
Parlee
0884
I will admit, I have not been a DIY guy. My only skill has been in writing checks!
However, I do like to understand the concepts and have a general idea of how an install should take place to determine if the work was done correctly. I do have a neighbor buddy who loves to DIY his Jeep; however, he is a “let’s wing it” style, guy. We could either complement each other or drive each other crazy as Bronco projects are crafted.
At this stage, it is AOK to have lingering questions, over time the picture will become more vivid. In the meantime, we can love the journey.
Slownstddy
Oct 7, 2020
553
1,158
2,964
Riddleton, TN, USA
Michael
Taylor
1508
Very zen-like..o_O
On the trail, I will have to fix any issues so knowing will be essential for me. I can swap out a u-joint with no problem but wiring a new switch or light keeps me awake at night.
Slownstddy
Oct 7, 2020
553
1,158
2,964
Riddleton, TN, USA
Michael
Taylor
1508
Give me a fuse block from 1965 and some round fuses and I'm good. These new cars have power control modules and voltage sensors that trip dumdum lights that have nothing to do with what you just put in and then you spend 17 hours searching through 700 miles of wiring and sensors and breakers and fuses that have backup fuses, the whole time your wiper blades are trying to take flight........talk me down......whew...:oops::oops: Almost fried a circuit....
Rhiostatic
Supporter I
Dec 21, 2020
106
335
1,605
Phoenixville, PA
Erik
Johnson
2185
I have 2 issues with power blocks. the first is when the wrong sort are used. this leads to improper install of the wire that can actually break the wires or can allow for water or other debris to cause arcing or a short. second is people tend to overtighten breaking strands and then moving the wire will cause a breakage. both of these defeat my intent, keep the wires as long as possible to avoid ever having to splice in new length and never to let the wire to loose conductivity.
