What should I do about stripped hole in transmission pan bolt hole causing it too leak?
Berthathebronco
May 01, 2022
B
Berthathebronco
May 01, 2022
3
0
30
829504
May 01, 2022
I have a 1990 bronco xlt with the 5.0 engine and e40d transmission.
SS Bronco
April 05, 2022
56
127
674
220677
May 01, 2022
I would recommend tapping the hole to one size larger. If I remember right they are 1/4” bolt , so 5/16” should do the trick. A hardware store should have a tap and bolt for under $20.
Sorry I actually have the 302 AOD transmission so do you know the size of that bolt?
Welcome to Bronco Nation!
I hope you get answers to your question and get the leak taken care of.
Would a helicoil or something similar work?
I'm going to move this to the appropriate section.
Good luck!
14U, Razorbullet
mike8675309
November 24, 2021
484
659
2626
201036
May 01, 2022
When you are ready to work on it. Pull one of the pan bolts and go to the local hardware store to find the size. Then you will need to measure the hole depth as well. From that you can identify the right Helicoil kit to use with your trans pan.
Now if you can't do that easily because of where you live, you could call a transmission shop and they should be able to help you with the bolt size if no one here has it.
2D Base Mansquatch: Ord 11-24-2021; VIN 3-16-2022; Schd 5/9/22; Sticker 5/4/22; Modules 5/10/22;Built 5/11/22;Shipt 5/12/22;Delv 5/24/22
Deano Bronc, Bronco 202?
Black Velvet
Michael Ashmore
March 28, 2022
361
508
2964
5480
May 01, 2022
Take it back and let the dealer ship replace it whiles its under warranty
That would have been great advice back in 1993 :)
2Dr Badlands - MIC - Area51 - 2.7 Auto - MGV - Headliner - High Pkg
Reserved 7/20/20 Delivered 5/6/23
"Ford said, hey we're gonna fulfill all reservations and pre-orders before we build stock units."
My son's '93 F-150 with an E4OD did the same thing and we did helicoil inserts in almost every hole. It was a solid repair. Be sure to use a good gasket and don't over torque the bolts.
