Anyone find any documentation regarding roof load/weight limitations for models that are optioned with the moonroof?
I just read that the load limit with the moon roof option is like 100 pounds, but thats prior to adding the rack weight. Not positive about that but a good start to verify from.
Did a little more research, 150lbs without a moon roof and 100lbs with a moon roof. These are total equipment weight when driving. The non moon roof can handle 600lbs parked, so if you had a RTT then you would be good. Only thing is with the RTT that is about the only thing you can have on top when you are driving.
