Washer/Defroster Connections in Bronco Hard Tops
Are you going hard top just to get the connections?
  • No, I live somewhere that requires a hardtop.
    Votes: 33 54.1%
  • Yep, just want to option but I'll be soft top or no top most of the time.
    Votes: 13 21.3%
  • No, I'm getting it anyway though. 2-Door Bronco!
    Votes: 15 24.6%
  • Total voters
    61
Administrator
Staff member
Super Moderator
Promoter II
Mar 19, 2020
1,821
10,208
Southgate, MI, USA
Liebmann
144
Broncos that are equipped with hard tops have additional plumbing and electical cables that allow for a rear wiper with fluid and defroster. Here's a closer look at those connections.
Note: Broncos windshield wiper fluid reservoir is behind the passenger side front fender and the plumbing for the rear wiper fluid is run for there.
lonzo71
Promoter II
Feb 20, 2021
609
1,164
2,964
Virginia
Matthew
Damba
2363
The 2nd and 3rd picture, where is that located at? Wish I could have zoomed out to see more but good pics and thank you @David and team for doing this!
Reactions: ATC Enthusiast
RonM0710
Promoter III
Sep 3, 2020
195
367
2,067
Spring City, TN
Ron
McCabe
1245
Is FORD going to make an option to add the Defroster/Wiper hook-up for those that purchase a Soft-top as original equipment.
14U
Mar 3, 2021
635
1,891
2,964
Tulsa, OK, USA
Jerry
Cook
2541
I was told No in a different thread a couple of days ago. And there is no pre run wire behind the panel for future hookup.
I would “ASSUME” that a factory install could do it later, But I am “Assuming “
It only comes standard for a hardtop build.
ResidualGenius
Champion II
Dec 15, 2020
3,277
6,467
Denver, CO, USA
Zach
Loescher
2512
I'd guess that it'd be hard to have it done DIO as you are talking about installing a reservoir, switches, wires, pump, tubing, etc, and would have to tear apart most of the passenger side to install everything and then rerun wires and control switches in the dash/steering column. But, anything is technically possible for the right prices.
Reactions: Gutter Clown
BigHoof
Advocate III
Feb 8, 2021
69
140
337
Western PA
James
Lentz
Just curious if you have the top off thus the wire and hose are disconnected and accidentally hit the rear squirter, will fluid shoot out all over? Having never owned a Jeep, wasn't sure if by disconnecting the wiper motor, the pump would also not run. (even though it's most likely up front in the reservoir)
ResidualGenius
Champion II
Dec 15, 2020
3,277
6,467
Denver, CO, USA
Zach
Loescher
2512
No, to my knowledge it’s all in the rear (outside reservoir in front)and you disconnect all power/hoses. From a picture I saw it looks like your air hose connectors where it seals when removed. Don’t know the technical name LOL
BigHoof
Advocate III
Feb 8, 2021
69
140
337
Western PA
James
Lentz
An air hose uses a Quick Disconnect. Did not see that but would make sense to seal it off. The picture above looks more like a clip to ensure positive locking together which is not really what an air hose connection looks like or how it works.
ResidualGenius
Champion II
Dec 15, 2020
3,277
6,467
Denver, CO, USA
Zach
Loescher
2512
That grey "button" is the release similar to pulling the "quick disconnect" ring down. I had this on another setup and works very similar and was great on that setup
Grapenutz
May 31, 2020
9
4
846
Kiel, WI, USA
Craig
Schwanz
2076
If they made the electrical and washer hose standard on all, I think a lot of people would get a soft top and order a hard top later
bhartness
Champion III
Mar 30, 2021
2
2
808
Draper Utah, USA
Brandon
Hartness
100893
While I don't really care so much about the electrical and washer connections, is there any insight that the hard top mounting locations will be present if I only order a soft top and not a hard top? I don't want a MIC top and would like to add a white hard top at a later date, but I'm concerned with Ford's statement that I can't add a hard top later. (I know anything can be done with $$$, but I don't want to involve fabrication of mounting locations)
Edit for clarity - I don't care about the washer connectors. I'm more concerned about the availability of the bolt holes to mount the hard top and whether those will be available.
RonM0710
Promoter III
Sep 3, 2020
195
367
2,067
Spring City, TN
Ron
McCabe
1245
FORD says NO! I am buying a soft top and would be willing to pay extra to have the hookups factory installed.
Buckin'
Champion III
Jun 13, 2020
585
955
2,607
Wilmington, NC, USA
2222
I would totally get a soft top now and hard top later if the connections were included.
I get it; it's a lot of extra equipment for something that may not be used. Jeep doesn't include it either. But I can still be bummed out about it.
Counselore
Advocate I
Jul 8, 2021
3
1
30
NC
James
Taylor
Seems you could add it later. Think of the business opportunity now. I'm on, the design wouldn't be that difficult. ‍♂
Jan 1, 2021
2,894
6,596
2,964
Maricopa, AZ
Tim
Kiely
2318
At least the soft top builds starting in September will have a everything for the HT installed. Unfortunately those who opted for the earlier soft tops will not have all the controls or pre-wire kit
Counselore
Advocate I
Jul 8, 2021
3
1
30
NC
James
Taylor
Maybe Ford could just buy the company that makes the J30 camper and upgrade us all.
  • Haha
Reactions: ResidualGenius
