WARNING Wheel Beauty Ring Removal - Bronco
B MIller
Nov 17, 2020
224
562
2,134
44
Sherwood, OR, USA
Brian
Miller
1791
FOLLOW UP: After informing Ford that my wheels have defects, they said the wheels are not covered under warranty, only the tires. The representative said the Ford Dealership Shop Manager is the only person who can override this. They took a look and are going to try to re tap the holes and put new bolts in. If the bolts break, they will submit a request to have the wheels replaced. Not a guarantee.
My understanding is the bolts used to hold the beauty ring on are one time use only. If you replaced the rings, there's a good chance they will break off. If that happens, you're screwed.
I'll follow up again after the attempt at repair.
By the way, when the dealership rotated the tires, they had one lug nut that was cross threaded as well and had to re thread.. Waiting on a replacement for that. Ugh!
MarkPS
Mar 6, 2022
472
793
1,356
Richmond, VA, USA
Mark
Spangler
By the way, when the dealership rotated the tires, they had one lug not that was cross threaded as well. Waiting on a replacement for that. Ugh!
Why does the Michael Keaton/frantic car build scene at the end of "Gung Ho" enter my mind ?
How does a mfgr. absolve themselves of warranty issues on a brand new anything you buy from them ? One time bolts ?! What kind of utter BS is that ? Do the rings need to be removed when you install new tires ?......
(And then disenchantment began to creep in to my mind....)
ChuckO
May 8, 2022
453
730
Left Coast
Charles
OBryan
5650
What? I though all new cars come with a 3 year / 36K miles bumper to bumper warrantee
Reactions: Bronco 202?
Bronco 202?
Sep 22, 2021
518
656
2,964
Arizona
Bob
Vogel
104442
Funny…. Ford is on this forum BUT when they see customers having a problem MOST of the time all you hear are Crickets. There is NO reason for the dealership not to make this right. Good luck .
Jan 1, 2021
4,615
10,273
2,964
Maricopa, AZ
Tim
Kiely
2318
Heck I’m surprised he didn’t get the “sorry to hear about this, send us your information in a DM” message.
Reactions: 14U and Bronco 202?
Bschurr
Jan 28, 2021
1,937
4,762
1,713
NY, USA
Barry
Schurr
I have removed my beauty rings twice and the bolts are not single use! These bolts aren’t under any significant strain fastening a cosmetic part to to the wheel face.
FOLLOW UP:
Ouch on the cross-threaded lug. That too is surprising since the wheel are installed via automated fastening tools at MAP
Bob Blaylock
Supporter I
Feb 20, 2022
119
222
771
59
N 38 29 W 121 26
Bob
Blaylock
I call solid digestive waste from a male bovine.
If what you describe in the OP is true, then that wheel is defective, due to an error on the part of someone at Ford who assembled it improperly.
Ford owes you a new wheel.
B MIller
Nov 17, 2020
224
562
2,134
44
Sherwood, OR, USA
Brian
Miller
1791
The Ford service manager said they are single use. That's from the service manager himself. He said there's a high chance they will have issues if removed and recommends replacing all bolts if removed. Just passing information along :)
Reactions: MarkPS
LagoCJ
Jul 13, 2020
302
909
2,607
Lago Vista, TX, USA
CJ
Frost
0232
I did all 5 of my wheels to get the rings powder coated to match my Bronc, and it took no time at all. However, I do agree that the Torx head bolts all over the Bronco are surprisingly soft. For the ring bolts, they have Loctite on the threads and in a couple of cases, the bolts took a lot of extra care to reinsert and get going straight in. Definitely not something I would do twice. Agree with everyone else, Ford should take care of this and make sure you are not riding around with the frustration of bad bolts and stripped Torx heads.
MarkPS
Mar 6, 2022
472
793
1,356
Richmond, VA, USA
Mark
Spangler
I’d say determine what size the Torx head bolts are and replace them with something of heartier stock before you Reinstall them
Reactions: LagoCJ
Bschurr
Jan 28, 2021
1,937
4,762
1,713
NY, USA
Barry
Schurr
The bolts are fairly common, button head M10x1.5 25
NB - the beauty ring bolts are not Torx fittings - they are Torx Plus. I think that’s why people are having issues because a standard Torx T40 bit will not provide the proper engagement that a TP40 will and the bolt heads will be more prone to damage when the improper tool is used.
Reactions: Deano Bronc
MarkPS
Mar 6, 2022
472
793
1,356
Richmond, VA, USA
Mark
Spangler
And that’s a problem right there why are they using niche fasteners the torque heads are fine but why use something that’s not the common typical Torx head ?
Reactions: Bschurr
LagoCJ
Jul 13, 2020
302
909
2,607
Lago Vista, TX, USA
CJ
Frost
0232
Good call...I did have to buy a set of TP bits to keep from doing too much damage to the heads. They still were super touchy and if I have to take the rings off again, I will be getting new bolts. Maybe SS, with a washer to keep the SS from touching the AL.
