Shift into neutral and shift the transfer case into what ever gear you want. If it doesn't go in, move forward a couple feet and try again.
If the transfer case is in neutral and won't move, shift transmission into drive or reverse, hit the gas a little , shift in neutral and try transfer case again.
If you are on a hill and can roll forward that can help too. Just don't try to shift while transmission is in gear.
