To prevent drilling too far install sleeve or thick piece of hose over drill bit only leave enough of the drill bit exposed to penatrate the panel your drilling problem solvedI think as the bit breaks through the inner shell, and you are putting any kind of pressure, it taps into the outer shell. Someone posted the other day that their dealership did this on the install. Off to the paint shop!
Just use a drill stop. And if you have someone else do it then make sure they use a drill stop. If they don’t have one or say they don’t need it they don’t know what they are doing.That is why I have been waiting to install it. I have had the table since the end of November but I am trying to find someone that I know won't dimple the door
mine arrived today, was hoping not to have to drill but oh well. I'm going to wait for Sunday to install if it doesn't rain...
JoergH
Champion II
- Apr 21, 2021
- 883
- 1,544
- 3,501
- First Name
- Joerg
- Last Name
- Hallbauer
- Member #
3682
I went with a third party table from Outdoor Adventure Products for, among other reasons, that they didn't require any drilling. It looks great, works like a champ, and holds more weight than the Ford table!
For more info check them out at: https://outbackadventureproducts.com/product/bronco-trailgater-for-2021-22-ford-bronco/
I’m doing a write up of the ford tailgate table tomorrow most likely. I’m the process of removing the absolute garbage rivet nuts they used for it. Should’ve installed it myself with decent hardware. Love it otherwise, but look at this weak sh**…I went with a third party table from Outdoor Adventure Products for, among other reasons, that they didn't require any drilling. It looks great, works like a champ, and holds more weight than the Ford table!
Buy aftermarket rivet nuts. The ones they give you are absolute trash. I’m going to go into more detail tomorrow, it save yourself time and headache, don’t use that aluminum trash.View attachment 30070
I had a Porsche tech (friend) come over and install this thing and his comment was, “who ever designed this is a professional a**hole.”![]()
We had to order a second package of hardware to affix it to the door because the first fasteners failed. A bit of a nightmare but good to go now.
Good to know. The instructions they also gave are trash the pictures and wording is very blocky and hard to read/see.
I’m going to be hopefully finishing mine up today or tomorrow and will do a write up with photos. Hopefully that will help if you need a bit more instructions that actually make sense.Good to know. The instructions they also gave are trash the pictures and wording is very blocky and hard to read/see.
As promised:
thebronconation.com
Ford Tailgate Table- Rivet nuts are absolute trash
As promised, here is a thread on the Ford Tailgate table and the only issue I’ve had with it…the cheap, aluminum trash they used for rivet nuts. I noticed very shortly after taking delivery that one of the nuts had popped loose. I ordered my Bronco with the tailgate table and was told it would...
Yep the fastgerners are junky. You have to tighen the crap out of them with that little disposable wrench or they start to spin and YOU ARE DONE!View attachment 30070
Got it installed I also replaced the aluminum expansion nuts with some
something stronger.
something stronger.
I put a strip of white acrylic behind the Bronco opening to hide the unpainted portion. It looks way better.Yeah it doesn't like to go together. Mine also isn't fully painted.View attachment 37732
yeah I put a black strip of plastic and glued it. I also put some jb weld on the lower right bolt that section kept sliding freeI put a strip of white acrylic behind the Bronco opening to hide the unpainted portion. It looks way better. View attachment 37758
I ordered a "TomGoo" rear gate-mounted table from Amazon, $93. Stupid me! It's a piece of &^%#$@!(&%#${+&#!! Afraid I got what I paid for...
This image from the Amazon listing. Don't, DON'T waste your money on it. Sign me: embarassed.
I absolutely hate Amazon these days. Nothing but cheap, Chinese, knock off products. Even all of the product descriptions are in broken English. Jeff Bezos can suck it.I ordered a "TomGoo" rear gate-mounted table from Amazon, $93. Stupid me! It's a piece of &^%#$@!(&%#${+&#!! Afraid I got what I paid for...
Nice. Thanks for sharing. Their version of the table is sweet.Rockslide Engineering I think has the best table and defiantly the best value at $275 compared to Fords $310
Thanks for confirming a decision I made after confessing to my bad judgment in ordering a cheapie off Amazon. I looked through a number of other sources, and ordered Rockslide's table. There's only one, right? Aluminum with a smaller upper shelf? Looks good. It will call for some very careful drilling, of course!Nice. Thanks for sharing. Their version of the table is sweet.
That’s a good one to go with. The ford one is nice, but weight limit is a joke and the nutserts are absolute trash. Otherwise it’s a solid table, but if I were to do it again, I’d go with the Rockslide one.Thanks for confirming a decision I made after confessing to my bad judgment in ordering a cheapie off Amazon. I looked through a number of other sources, and ordered Rockslide's table. There's only one, right? Aluminum with a smaller upper shelf? Looks good. It will call for some very careful drilling, of course!
I was going to order the Ford OEM table but when I found out it required drilling into the tailgate, I got skiddish. Mabbett just released one a few weeks ago. I have a couple other of their products and have been happy with those. This one doesn't require any drilling. I'm getting it next week. Will report back and give an update.
