Sep 11, 2020
FlourmanSep 13, 2020
Mud,Sweat and Gears
Bronco V-8Sep 13, 2020
Bronco guy doing Bronco-ey things with his Bronco
The BronzeSep 13, 2020
Sep 13, 2020
Nice write up.I spent a good amount of time looking at it over the last 4 days. Here is my thoughts:
- The black exterior color hides some of the lines. I really like black, but it doesn't highlight the cool lines on the Bronco.
- The black leather looks great. Wish it was on the FE; nobody there believes there will be another option for FE
- I like that it is smaller than I anticipated. I am taking this off the beaten path and the smaller the better.
- There is a ton of headroom for the front occupants; Tim was 6' 2" and he had at least 4-5 inches of room above his head.
- No storage under the rear seats. The two door looks like it will be hard to fit all the gear you would need for a long weekend if you have passengers in the back, but I once took 4 people in a 78 Civic Wagon on a 3 day camping trip with bikes and all. The Bronco rack looks like it will handle a decent amount of gear.
- The 285/70R17s on the Badlands look too narrow. It will keep the body clean, but I know now that I want the Badland flares on the Sasquatch package to make the tires sit right (or some real 12" wide tires).
- The hitch shouldn't cost $600. It is a small bolt-on assembly (from what I could see) and a 4/7 gang connector.
- The winch on the front needs more work; the Ford guy I spoke with said they spend a good amount of time working on approach angle with the winch mount, but it simply sticks out too far for decent rock climbing. It will work great if you don't pull up to 3'-4' rock faces.
- The stereo speakers are located in the front and the rear (no 4 door to see if there were centrally mounted speakers between front and rear row seats). The speaker pods in the back look like they will project to the front well!
- The switch pods look great. The dash is very clean and not cluttered. There is adequate space between the driver and the dash, it doesn't seem cramped.
- I never saw the engine compartment opened, so I don't have any insight there. Looking forward to the 2.7L though.
- The antenna sits in front of the light pods that were installed in front of the windshield. That didn't look quite right.
- Not sure if the mirrors actually folded, but they large enough to provide good rear visibility.
- The turnbuckles and limb wires looked weird. I get it, and have needed it before, but I won't be rolling with these things installed.
- I wish the taillights were recessed more like the original bronco. I feel they will get damaged easier when backing up against trees (such as when turning around on a tight trail)
Moab or bust!!!
Deano BroncSep 13, 2020
Yeah, I've heard so many conflicting reports if they come out or not on the 2 door. It would be a nice feature for sure.I can not believe the 2 door modular top will not have removable windows :(
C'mon Ford! What are you thinking!?
okie4570Sep 13, 2020
TorgSurvSep 15, 2020
They definitely will be removable on the 2dr modular hard top. The one they had at the Bronco Super Celebration did not have removable windows because it's a bit of a Frankenstein vehicle. Ford reps there confirmed that they will be removable on the final production version.I can not believe the 2 door modular top will not have removable windows :(
But later, at the CelWest event, it was stated they won't be removable. Saying that they "definitely" will be is a little optimistic I think.They definitely will be removable on the 2dr modular hard top. The one they had at the Bronco Super Celebration did not have removable windows because it's a bit of a Frankenstein vehicle. Ford reps there confirmed that they will be removable on the final production version.
bdawson24Sep 29, 2020
GaryB2220Oct 08, 2020
Just remove the entire top shell. It is kinda weird not being able to remove the rear windows when you have the panels removed. But if you are going with a roof rack anyways, it won't matter because you can't remove the rear panels with the roof rack on. Would be nice to be able to pivot the windows out to get some better air flow in the back thoI can not believe the 2 door modular top will not have removable windows :(
Oct 08, 2020
The seats don't fold flush? Both two and four door models? I guess I didn't realize that. I'll have to find a photo or something to see. How do the look when down?They got a lot of things right.The attention to details such as Bronco bolts is impressive.
But there are a few things that miss.
They need an NA engine.
No manual with the 6 cyl.
The instrument cluster.
Rear seats do not fold flush with floor.
No dual batteries.
4" step to the cargo areaThe seats don't fold flush? Both two and four door models? I guess I didn't realize that. I'll have to find a photo or something to see. How do the look when down?
Unless you get the slide out shelf in the 4-doorThe seats don't fold flush? Both two and four door models? I guess I didn't realize that. I'll have to find a photo or something to see. How do the look when down?
