anybody got some ideas on separating a front brake drum from the wheel flange? tried heating with mapp gas. tried hammering bewtween the 5 studs. tried hitting it from the back side toward the outside of the vehicle.
even tried hooking two gear puller arms to the edge of the drum and trying to use that pressure to separate them. on every try I sprayed the center hole and the stud holes with 50/50 acetone/ATF.
I haven't worked on a Bronco's disk brake system or anything quite that old but I assume it is close to what is out there in the last 20 years. Take this with a grain of salt.
I know I have had trouble getting them off when the internal brake shoes are out expanded far enough that it won't get past a groove on the drum that has been created over time. Is there a way to turn the show adjuster on the back side to bring the pads in?
I've had trouble getting rotors off the hub also and I usually have to heat the intersection point at the spindle while someone is banging on it from the backside. It can be a bitch to get them apart sometimes. With the setup you have pictured, heat it up and bang on it with a BFH.
