Oct 13, 2021
YouTube: youtube.com/@ragnarkon
Burrito Connoisseur
RagnarKonOct 13, 2021
Ford has confirmed to us that Sasquatch pricing is not an error in pricing list. Manual and Automatic Sasquatch cost the same.Forgive me... but I'm going to lean into some of the Bronco Nation moderators (@Laura / @David) to see if they can shoot us a question over to their Ford rep about the 2022 model.
If you option in the Sasquatch package with the manual transmission... it bakes in the cost of the automatic transmission without actually giving you an automatic transmission. Truthfully this is also what the price list said, and a lot of us in the community just assumed it was an error since the price list had multiple known errors, and it just doesn't make sense to have us pay the cost of an automatic transmission if we're not getting one.
But now I'm not so confident that the price list was incorrect. :confused:
Also... if anyone else gets the answer from their dealer, social media, etc. feel free to post the answer.
Burrito Connoisseur
redvettx2Oct 13, 2021
Mud,Sweat and Gears
Bronco V-8Oct 13, 2021
Burrito Connoisseur
Yeah tell me about it.Guess they dont want to sell them
Mud,Sweat and Gears
Crazewaffle7Oct 14, 2021
So let me break it down how incredibly stupid this is.
If you have a 2-door on order...
If you have a 4-door on order...
- If you have a Badlands on order... there is absolutely ZERO reason to get the Sasquatch package if you have a manual transmission. The Sasquatch package essentially just becomes a $4090 set of 35" mud-terrain tires. Save yourself money and get the 35s aftermarket.
- If you have a Black Diamond on order... the Sasquatch package makes the order MORE expensive than the Badlands w/o Sasquatch. That combined with the previous point means it makes NO sense to get Black Diamond with Sasquatch.
- If you have a Big Bend on order... the Sasquatch package makes it roughly the same cost as a base Badlands. So that combined with the 1st point means it makes NO sense to get Big Bend with Sasquatch.
So essentially the ONLY trim where it makes sense to order a manual transmission with a Sasquatch package is the Base 2-door trim (it isn't even available in 4-Door). And even then... that's a super expensive upgrade.
- On Badlands... much like the 2-door... is also ZERO reason to get the Sasquatch package because it is a $4090 set of tires.
- On Black Diamond, there is less than a $1000 price difference between BD w/ Sas and BL w/o Sas. You would be stupid not to upgrade to the sway-bar disconnect for less than $1000.
- On Big Bend... much like the 2-door ... the Sasquatch package makes it roughly the same cost as a base Badlands.
What a epic fail.
Burrito Connoisseur
RagnarKonOct 14, 2021
Ah… my bad I didn’t really make my point that clear yesterday because I was still really frustrated about the whole thing. I wasn’t comparing Big Bend to Black Diamond… I was comparing Big Bend to Badlands.I was actually pricing out my 2 door manual Big Bend with sasquatch package now vs 2 door black diamond with sasquatch. I added a heavy duty bumper and auxiliary switches on the Big Bend to make the order how I want it. The Black diamond includes the bumper and switches. When comparing the final cost of the Big Bend vs Black Diamond with the same specs, the Black Diamond was $2,000 more. From what I saw both had the same features added, unless I'm missing something that the Black Diamond has that is "special" versus the Big Bend?
redvettx2Oct 14, 2021
So, in effect… it costs less than $1000 to upgrade to a vehicle with a sway-bar disconnect, and the only thing you would be missing out on is the 35” tires. That’s a no-brainer in my mind.
- The Big Bend 2dr, with Aux switches, the bumper, and the Sasquatch package is $43,685
- The base 2-door Badlands already comes with the Aux switches… as well as the upgraded axles, gear ratio, and upgraded suspension that is in the Sasquatch package. In addition it also comes with the sway-bar disconnect, upgrading signature lighting, etc. Add on the heavy-duty bumper and the cost comes out to be $44,565.
Even if you really wanted the 35” tires… a set of Goodyear Wrangler Territory 35” M/T ties (which is what the Sasquatch package comes with) is roughly $1500 for a set of five if you bought them separately. Meaning it is less than $2500 to upgrade to a sway-bar connect, and you get an extra set of tires that you can use when not off-roading to save MPG… or sell/trade/whatever.
That still makes more sense in my mind than going with the Sasquatch package on the Big Bend or Black Diamond trims.
Burrito Connoisseur
Each trim has it's own unique flair, but it's largely either interior or exterior styling. From a strictly functionality perspective you can more or less option one trim to look like another trim... EXCEPT for the sway-bar disconnect, which is only available in Badlands.So there is nothing different between the models except what is "standard" and originally included? You can add stuff to one model to make it have the same specs as another and there is nothing really different between them at that point. Until you get to the Badlands because you cant add the sway bar disconnect to the lower models.. correct?
Yeah, unfortunately, you're only going to get the $400 price protection. So you'll have to account for that in the final cost. The cost difference is largely due to the cost of the of the heavy-duty bumper, which used to be standard on Badlands but is now just an option. The standard Badlands bumper is called the "capable bumper", and looks similar to the plastic bumper that is on Big Bend, except it is made out of powder coated steel instead of plastic. If you do a search for Capable Bumper on Bronco Nation you should see a few posts/articles about it that gives the details.Last question, am I going to get screwed in pricing switching from a Big Bend to a Badlands because I'm locked in with the price for the original order? Am I going to have to pay that difference? The Big Bend is $400 price protection and Badlands is $975 for 2 door.
Burrito Connoisseur
Yes... I think you are on the right track.Been talking to Ford about this and running numbers, poke some holes in my argument here:
Last week, when the MY22 Bronco Order Guide and pricing lists made their way into the public eye, the Bronco community noticed that Sasquatch pricing seemed off. Manual/Sasquatch and Auto/Sasquatch combos weren't producing differences in price that we expected. After extensive conversations with our contacts at Ford on this issue, here's my report.
Ford's stance is that Sasquatch pricing didn't change, they moved the price of the transmission into the package and that pricing protection will take care of the balance for folks whose MY22 build includes a manual with Sasquatch. To test this, I went to the Build and Price for both MY21 and MY22 and built out a 4-door Broncos with Sasquatch. I added no other items to the builds. The MY21 Badlands came to $50,175 without the acquisition fee. The MY22 Badlands came to $50,425, a difference of $250. A 4-Door Base with Sasquatch produced the same $250 difference. Then I ran the other trims through the same exercise and they also produced the same $250 difference with the exception of Wildtrak, which produced no difference.
This tells me that the price of Sasquatch package hasn't changed and that $250 is probably the year over year price increase across the board for Bronco, except for Wildtrak which now has a soft top instead of a hard top standard. It does seem like automatic transmission costs are baked into MY '22 Sasquatch since adding an automatic transmission to trims that have a manual standard produces no extra cost in your build. However, if you figured that MY22 Sasquatch on a Badlands should produce a $1595 savings year over year then you'll be disappointed. But you won't be as disappointed as you might expect to be because it's not a $1595 increase for a MY22 Badlands with Sasquatch, it's a $250 increase from a year over year adjustment and you get an automatic transmission as a no cost option. On top of that, you have price protection if you ordered/reserved by 19 MAR 2021 so if you're perfectly fine with the new bumper, you're pocketing $575 when you take $250 from the $875 in protection that is being provided for 4-Door Badlands.
AcesandEightsOct 14, 2021
But from the customer's perspective, manual transmission users who are looking to get the Sasquatch package have to pay for the automatic transmission even though they aren't getting the automatic transmission.
MicahmanOct 15, 2021
