Removable Hoop Steps for Bronco
Feb 25, 2022
The recent update to build and price brought a new option for removable hoop steps that seem to attach to Bronco. We've gotten a few pictures of what they look like on and off the Bronco. This will give you some idea of what is involved with removing them and putting them back on again.
EDIT:
Some clarifications from Ford.
1. The rails that the steps attach to are not the same as the rock sliders that are available on Bronco. They cannot hold the weight of the vehicle.
2. The steps do not work with existing rock rails. It's a different profile.
Broaddict, Crowza
Moab or bust!!!
Feb 25, 2022
EDIT:
View attachment 29687View attachment 29689
Will these steps work on existing factory sliders or are the sliders different when you order the removeable steps?
TitsLaRue, Rgwinn
That's a terrible idea, when do we start?
Feb 25, 2022
Any chance we can get these "after the fact"? I took delivery of my Badlands with the rock rails in Jan. and was looking at replacing the rock rails with aftermarket. But this would be an interesting alternative if it can be added to my existing Bronco!
4 Door BadSquatch | Soft-top | Velocity Blue | 2.7 Auto | Towing | Lux | Leather
NVR SETL, Sdakotabronco
Feb 25, 2022
@Deano Bronc Great minds think alike.
Dirt Dog, TitsLaRue
Feb 25, 2022
I'm thinking about the set from Rough Country. There are no rocks in S Florida.
I wonder if those are the same rock sliders as on the current production model. They look to be a little lower and/or further away from the rocker than what I've seen in person. If the same, hopefully these can be purchased and installed on current model. I ain't skeerd to do a little drillin'.
On Order, 11/15/21: MY22 Badlands 2-dr, Carb Gray, 2.3L, 7spd, SAS, Lux Reorder, 9/23/22: MY23, dropped tow.
Sche'd Production: 11/28/22, Modules Live: 11/30/22. Delivered 12/02/22.
🐎Moab bound🐎
Feb 25, 2022
I don't have a great mind like @Deano Bronc and @JoergH, but I'm thinking like they are. I really want to keep my factor sliders and need steps. But, don't wants steps on there if I do go rock crawling.
Hi y'all, Lauri here and I am the proud owner of a MY21 Badlands, SAS, 2.7 auto, 4 door, soft top, Cactus Gray, no reservation, ordered 9/11/21, Took delivery 1/8/22!
Rgwinn, Deano Bronc
Exactly what I need for my FE, hopefully they add them to the catalog
Ordered: 4-Door First Edition - Rapid Red - Black Seats - MIC Top - Build Date: 10/25
In Garage: ‘62 Red Vette - ‘07 Black Shelby Ragtop - ‘21 F150 Platinum PowerBoost - Rapid Red
From Ford: Hoop steps will be available through the Ford Performance on the dealer channel, stock is coming this summer.
Ditchrunner, Broncofly
It's a good question, seems like they might require some drilling and threading but I don't know.
Slownstddy, Rgwinn
Thanks for the update @David
Hobgoblin
Thanks David. Looking for options. Nice to see that more are popping up.
Dirt Dog, Crawler Green
Moab or bust!!!
Feb 25, 2022
Thanks for the clarification!
Dirt Dog, Bt_ostate
I think these would be great as I dont Intend on any heavy rock crawling but, notice that If you damage the rail on a rock or obstacle, you wouldnt be able to
Are they assuming I weigh as much as the Bronco? Then i cant get in it since its load rating after the vehicle weight.....HMmmm...
Dont mind the first part of that....
This is a good clarification. So many people were thinking they were just buying a hoops or stirrups. The rail as depicted on the BnP was clearing not the factory rock rail, nor did that really make any since if it was available on all models.
I think I will stick with the tube steps for a bit more flying rock protection for now.
95 Eddie 5.8 Windsor 2021? nope, 2022?, wait 2022.5 HOSS3.0 equipped WildTrak/LUX/Leather/MIC. 7/14 RES
Bt_ostate
There are also these that were put out today.
IAG New Product Alert - EZ-Step Add-on
EZ-STEP V1 SITS EVEN WITH THE TOP OF THE OEM ROCK RAIL
The V1 EZ-Step is located at the same height as the top of the OEM rock rail. This location provides the best ground clearance while still improving your ability to get in and out of the vehicle.
Even when located at the top of the rock rail, the step height is lowered by 5 inches from the door sill opening. The added foothold prevents the need to step on the painted door sills or to slide across the seats. The textured black powder coat on the EZ-Step prevents slippage and adds a unique look to the exterior of the vehicle.
EZ-STEP V2 SITS 2" BELOW THE TOP OF THE OEM ROCK RAIL
The V2 EZ-Step is located 2" below the top of the OEM rock rail. This location allows easy access to the vehilce while still maintaining good ground clearance.
With this mounting location the step height is lowered by 7 inches from the door sill opening. The added foothold prevents the need to step on the painted door sills or to slide across the seats. The textured black powder coat on the EZ-Step prevents slippage and adds a unique look to the exterior of the vehicle.
https://www.iagperformance.com/iag-...PvvZCe3KPqg9tRDZ6luoLm2gymxy_EYtlxzkw=.SW8CGN
MY22 Badlands, Eruption Green, Sasquatch, 2.7, Lux. Res. Date 5/27/21, Ordered 10/15/21, On Ice Mountain…
Broncofly, Rgwinn
There also these that were put out today.
Glad someone else saw this. These look pretty nice! Thanks for sharing.
Hobgoblin, BTilbury
Jawz
Feb 25, 2022
Lets talk about the sliders that Ford should have made....
Broncofly
