Aug 20, 2020
I just bought a 1995 Bronco and the rear window does nothing. I was told it worked in January/February.
The window is up so I can't put the tailgate down. It also does not have the tailgate key.
I have pulled the tailgate cover and pushed on the key up and down buttons from the inside and nothing happens, same thing from the switch in the dash.
My idea is to jump the motor from a small battery to see if it does anything.
I am wondering also if this might be related: The in door lamps and the exterior lamp at the rear are always on, I have to remove the fuse currently when not in use to keep from draining my battery. It does not seem to be caused by the door buttons. I am wondering if it thinks the tailgate is open, thus causing my lights to be on and the switches to not respond. I have pressed on the tailgate hard and it is latched.
Thoughts?
Thoughts?
