Oct 27, 2020
Jolly RancherOct 27, 2020
AcesandEightsOct 27, 2020
Mud,Sweat and Gears
Bronco V-8Oct 27, 2020
Mud,Sweat and Gears
The parts dept should be able to get grills, I plan on getting another one and painting it white for my Big Bend..It's looking like I'll go with the Outer Banks and the 32s. Hate the OB "not a grille" grille though. Hoping it's true that I'll be able to swap it out for the Badlands one.
TorgSurvOct 28, 2020
okie4570Oct 28, 2020
Good point, the tires are the last and largest gear in the system, from the transmission to t-case to differentials, they then have to turn the next gear in the chain which is the tires. What's nice though is the tires are the largest and therefore the least impactful (in some ways) to the system. A change from 31" to 35" tires is only a 12% change (granted you have a small weight difference too). The gearing difference between 3.73 and 4.7 is much more significant, at 27%, and the torque converter of the auto trans makes up for the 12% difference for most people in most situations. First gear in the auto is lower than first in the manual (not considering the "granny" first, it's 10% lower than the manual and offers a lot more gearing options). If you really think you'll jump from 31" to 35" tires (as an example) you're probably better off getting a 4.27 and auto if that is a combination; however, the auto is going to give you a low first gear, off road or off the line. That all being said, I think the auto, with 3.73 or 4.27, are going to serve a person well that is more concerned about economy and snow/mud.
AcesandEightsOct 28, 2020
Jolly RancherOct 28, 2020
BBNationJan 23, 2021
Bronc96Feb 17, 2021
