Jan 22, 2022
I posted this guide on another forum, and it seemed to help folks, so might as well post it here as well.
As most of you know, the tow package is one of those heavily constrained items that is holding up a lot of Bronco builds. I don't have any insider information, but I personally expect this to become THE deciding factor on whether most people get a build in the not so distant future. Especially as the MIC hard top supply situation improves throughout this year. Keep in mind this post is designed to be high-level, so I glossed over a lot of the nitty-gritty details. But definitely don't mind diving into those details if there is interest.
The benefit of the tow package on the Bronco is the 7-pin connector, compatibility with a trailer brake controller, and some additional integrations with the Bronco's safety systems (BLIS, sway control, etc.). Of those, the biggest benefit is the trailer brake controller compatibility. Note the trailer brake controller itself does not come with the Bronco's tow package, but it’s easy to add one on if you get the tow package. You still have to take apart and drill a hole into center console for the gain knob to install it (if you follow Ford's instructions), but it’s relatively easy. Therefore, if you have no intention on ever installing a trailer brake controller, I would absolutely drop the tow package and get the following:
You can either install them yourself or have your dealer do it. And if you pay for it with your FordPass points it becomes cheaper than the tow package. You may even be able to have your dealer wave the installation fee—they also have a vested interest in getting your Bronco built and sold to you.
Edit — Apr 28th, 2022 — The instructions to install the hitch and the wiring harness are now attached to this post, if you want to review the process for yourself.
Now you may be asking to yourself… do I need a trailer brake controller?
That depends on many factors. In most states, you do not need trailer brakes until you tow above 3000 lbs. The Bronco’s max tow rating is 3500 lbs, but if you load the Bronco itself up with additional gear, that tow rating drops to around 3000-3100 lbs. So while the answer is, ”it depends”, I can make generalizations….
And finally… the states where trailer brakes are required under 3000 lbs (to the best of my knowledge):
Apologies to our Canadian friends up north, not super familiar with the trailer brake laws up there. Only have a rough idea what is required in Quebec (1300 kg) and Ontario (1360kg) , the rest is a mystery to me. EDIT— Did some research last night and about half of the Canadian providences mimic US law, the other half do their own thing. I would still do your own research just in case I'm completely misinterpreting Canadian law... BUT... It seems most Canadian providences require trailer brake controllers on trailers over 1360kg (~3000lbs) except the following:
- If you are towing a marine trailer for a boat, jet skis, etc. the answer is NO. Marine trailers almost always have passive surge brakes that do not require a brake controller.
- If you are towing a utility trailer, the answer is NO. The vast majority of utility trailers small enough for the Bronco to tow will either have no brakes or surge brakes.
- If you are towing a pop-up camper, teardrop trailer, or other small camper, the answer is PROBABLY NOT. You can buy these trailers with electric brakes, but it is often an optional upgrade and not a standard feature. Whether you’d want electric brakes or not is up to you (see the next bullet).
- If you are towing an overlanding or off-roading trailer, the answer is PROBABLY YES. Most expedition trailers will come with electric brakes. If you are doing more extreme off-roading with a trailer, having electric brakes helps dramatically when trying to control your vehicle. That said, if you aren’t doing extreme off-roading with your trailer and will be driving on decently maintained forest service roads or camp ground roads, electric brakes don’t really help you that much.
- California
- Idaho*
- Nevada
- New York*
- North Carolina
- Mississippi
- Northwest Territories (required regardless of weight)
- Alberta
- Manitoba
- Yukon
- Quebec
2022 4dr Badlands, 2.3L Manual, Mid pkg
YouTube: youtube.com/@ragnarkon
TMars, MCBronco777
