Yes the sawinaw pump is mostly know as the best pump. The power steering box is what i realized is key to safety. I had the sawinaw pump from a Nissan Xterra, 3 bolts. The pump was good, but the steering box failed. While off-roading all 3 high grade bolts sheared off. I guess i was luck it didn’t happen on the highway. I replaced the steering box with one that James Duff sells, 4 bolt. I also got their frame reinforcement kit and BC Broncos frame reinforcement kit and installed both. Two plate on each side and metal sleeves so the frame could not collapse. If the bolts loosen due to various things one the frame collapsing it is very easy for all bolts to sheer. So do yourself a favor and reinforce your frame.
Check out my instragram #KD6TAV or my YouTube KD6TAV
