Thought I'd share this. I was doing an engine swap with a 289 into a car that didn't have a V-8 option. The 289-302 car engines use a front sump oil pan I needed a rear sump. A little reserch I found out Broncos 66-77 use a rear sump pan. Swap pan,pick up, stick tube and stick and your done. If you get a Bronco with a bad engine make sure you keep these parts if putting new engine as it might not have the proper pan etc.
