I received my molle panel from M2M. Very disappointed. The panel holes aren’t quite right to lineup in the front. Makes the panel buckle a little bit. since the hole in the front was slightly misaligned it also made the screw impossible to seat. The screws were very difficult to seat fully in the front location (where you remove the factory 7 mm bolt). They should’ve also given you longer screws to go in to the grab handle location. I had to go to Home Depot to buy better hardware as the Allen screw that they provided began to strip since the fit was so poor with the panel. I replaced it with a proper hex bolt. I had to use pliers to back the Allen head out since it had stripped. And yes - I am very competent mechanic and I did not strip or cross thread the bolt. It’s just a poor fit.
Speaking of the grab handle location, when you screw the molle panel in and tighten it down, the panel is thin gauge - thin enough sheet metal that the panel actually bends in around the bolt heads. Admittedly I screwed them in tight, but since it’s a grab handle you need to.
Lastly, when I received mine there were some chips in the finish. I had to get a black textured paint to touch it up before putting it into the bronco.
Bottom line, not thrilled with the purchase.
22 Badlands SAS Lux Hot Pepper
