Jul 06, 2020
V8_PowerJul 06, 2020
BigAng96Jul 07, 2020
V8_PowerJul 07, 2020
I was worried that people would say that, I really don’t want to have to tare the motor down. If I do pull the heads off though I’m thinking about replacing them. Summit sells rebuilt heads for $250 a pieceI had to take the heads to a machine shop and get them machined out I tried everything couldn’t get it out on my own
Yeah I was thinking about drilling them myself and just putting jb weld on the stud if I hit water but I was worried about leaks and I see you didn’t have good experience with that yourselfYeah I know it’s a head ache but I did the same thing but I still had my originals machined and I kept them as a just in case lol I hoard my parts because you never know when you’ll need them , I also took it to a machine shop cuz I was already getting frustrated and didn’t wanna destroy them mine was sold to me with the bolts snapped and they jb welded it all back together it held for months and one day started a huge leak so you can imagine the mess I had to get through in the first place lol , hope it all works out
BigAng96Jul 08, 2020
Bruners4Jul 13, 2020
Bronco92Jul 13, 2020
V8_PowerJul 13, 2020
Yeah I'm hoping I can get them out, also my snap on dealer told me he might be able to get a hold of a variable stud drilling template if I cant get them out with the welder135 K is not bad mileage , if it has been taken care of. I actually had the same issue and had a Local Muffler shop R&R three studs, the downside I had to have him install my shorty Headers which labor cost was about$60.00/ stud and $200.00 for Header install. Much quicker than pulling the heads.
Carl AastromJul 14, 2020
Jamie.yorkbam87Aug 12, 2020
Easiest thing I did was take the front cap of the bronco off so you can get to the heads and you don’t have to yank them off or pull the engine out. Heat up the broken bolt With a bottle torch and use bees wax then a reverse drill bit and go slow and it will back out. Option b is drill and tap or buy a bracket kit. When installing new bolts even if the old ones came out fine clean the threads in the head so they go in easy.Ok Guys so Im in the process of putting Hedman long tube headers on my 95 bronco 351w. Im going to post up pictures and what I used as I go but I.m starting off today looking for advise. I have manifold studs snapped off in the head and I am having a really hard time getting them out. Wasn't expecting this to be a problem since they are cast iron heads but this thing is becoming more difficult than a 5.4! Anyone ever come across this and if so how to you get them out?
paul rondelliAug 12, 2020
V8_PowerAug 12, 2020
Short tubes are much easier to fit and easier to make the rest of the exhaust for, I dont mind doing the extra work so I wanted the sound of long tubes. I was not expecting it to be this difficult when I took it apart but I ended up pulled the heads off this last weekend. Couldn't get the old studs out and I wasn't about to try drilling 6 studs in the engine bay. Pretty sure I am going to order new heads this week. How rusty is your bronco? do you know if the manifolds have ever been replaced?My 1996 just became smog exempt this year. This was been on my list for a decade or more... but always put it off because of the fear of creating more work... for something that is really not broken. Keep us updated because she just hit 175,000 miles and long overdue for a high flow cat and upgraded headers. I always was told that the shorties are easier to fit than the long tube... especially on the passenger side?
paul rondelliAug 13, 2020
V8_PowerAug 13, 2020
paul rondelliAug 14, 2020
