Jun 02, 2022
Just thought others may like to know that there is an option when installing the controller. My grandsons are like monkeys and have been known to climb over the console which I feel would inevitably render the control knob destroyed if placed per instructions. There is plenty of room to place all components of the kit on the driver's side by popping the hinged lower dash panel. It is how you access the fuses as well. Used the conical step drill to make the hole on the headlight switch panel. Discarded the supplied bezel. The factory wiring harness for the controller is already located right above the accelerator pedal. Be careful popping it loose, lots of razor sharp objects under all vehicle instrument panels.!! Ouch.! Very quick install without removing console or glove box.! The module is stuck to the metal plate under steering column , using supplied sticky tape, with a couple zip ties for insurance (I did trim the tails off after the pic.!).Hooked to a trailer and the led lights up when applying the brakes. True plug and play for those of us with the factory tow option. If anyone else has posted using this location for the controller switch/knob my apologies, many searches did not find this method. :)
F ederal O wnership R espectfully D eclined
AngusMac13, macblaster
