Good question and an area of much debate. The Squatch and Badlands suspensions are very similar as both are the Bilstein HOSS setup with position sensitive dampers. The difference is only the "high clearance" variable and Ford really hasn't been clear in what that means. We know the Squatch has bump stops to limit travel but not sure about the rest. Esteban did say they are very similar but have different part numbers which leads me to believe the Squatch either has a slightly taller coilover or spacers of some sort to accommodate the 35s. Some believe there is no difference at all and only the bump stops but I am not so sure...
