GMRS antenna mount inside vehicle
JetMech
Feb 10, 2022
10
34
Mesa, AZ, USA
Robert
Charboneau
Where did you get the bracket. I think I want one just like that.
Made it from a piece of flat bar stock I bought at Home Depot. Cut it to size then drilled, bent and painted to finish it off. The hole for the antenna I used a $5.99 step bit from Harbor Freight.
MIGeezer
Super Supporter III
Dec 6, 2021
795
752
1,713
Michigan
Dave
Hemmerly
Does the speaker in the mic with the controls provide quailty sound? I spoke to folks that had the same type mic for a Cobra CB and they ended up adding an aux. speaker to hear it.
Slownstddy
Oct 7, 2020
1,547
3,377
2,964
USA
Michael
Taylor
1508
I was going to mount it inside as well but the enclosed cabin would reduce distance and cause interference. Plus eratiate me and the mrs. So I mounted my antenna on the 3rd stop light. Seems to work good. Wired directly to the Battery and no holes drilled.
Mal
May 21, 2020
1,148
2,742
Albuquerque NM
0283
I have a 275 and have no issues with the sound. It is plenty loud and easy to hear.
Hkak45
Sep 11, 2020
544
1,481
2,964
North Central Illinois
K
R
The big benefit to hard mounting the GMRS radio verses the hand held is you get much better antenna options. Most hand held antennas are pretty dinky. Nothing wrong with them (I use hand helds all the time when driving with people and we can communicate car to car easy, just without as much range as something more powerful), but you get a lot more capability with a better antenna. There isn't much functional difference between some of the higher wattages (a MXT275 at 15 watts is not 66% worse than a 50Watt MXT575) because obstacles in the line of sight will limit you much more than power. Better antennas help, but it doesn't matter how much power you are pushing when you are terrain masked, you are terrain masked.
In a closed metal car, a handheld is at a disadvantage because the car's structure acts like a faraday cage and can mess with the ability of a hand held to receive and transmit. That's much less of a problem in a soft top (or even hard top) Jeep or Bronco just due to the nature of the construction. @AcesandEights is exactly right about hand helds on trails- the line of sight is really the limiting factor, but they are going to be great for spotting and communicating with the group. Always a good move to have a couple hand-helds around to give to your spotters or other people in your group. I always clip one to my elderly father in law's belt whenever he goes somewhere with us just in case he gets lost. Cheap insurance.
The other advantage is that generally speaking, a hard mounted radio will be more likely able to use your local repeater network. There are many different hand-helds that can do this too, but almost all the mobile radios can and that's a benefit where I am. Clearly a nice to have not a have to have so YMMV, but a good repeater helps solve that terrain masking problem. this is probably not an issue on a trail ride- you are probably always going to be within LOS (radio wise anyway) so not something to really worry about. Here in NM, there are lots of places with no cell service, but I can hit the repeater network from my car and could probably call for assistance in a pinch.
Finally, and maybe this is just lazy on my part, but a hard mounted radio is just one less thing for me to loose. That's worth something to me.
@jimFish you asked about radio waves in the cabin- anytime you are irradiating anything that's going to be a concern. That being said, I have no problem using a 5 watt handheld right next to my head and in a closed car. I might not be super calm about say attaching an antenna to a hard hat and running a 50 watt radio through it, but that 15 watt MXT 275 is going to be okay. In a Bronco or Jeep, there is an escape route for the wave so there is not going to be a lot of refraction in the cabin. Also, you are only radiating when you are transmitting so thats a pretty small time window. But again if its a concern, there are all kinds of good mounting options outside of the bronco- Rear mount, lip mount on the hood, cowl, or even on the trail sights.
What do you think about a handheld that can use repeaters and just hooking up the handheld to an exterior antenna on the car when in vehicle? So essentially hard mounted when in vehicle but with the ability to disconnect and put on smaller antenna when on the ground. Since you said 50W vs 5W isn't huge disadvantage with a proper antenna
JoergH
Champion II
Apr 21, 2021
1,023
1,731
Saugus, Santa Clarita, CA, USA
Joerg
Hallbauer
3682
That would be better than the antenna that comes with the hand held for all the reasons discussed. But let me give you a different perspective about the mobile vs hand held. Everything that has been said about simplex communications being LOS is absolutely correct. However, when you are trying to key up a repeater you'll find that some of them are up pretty high (i.e. within some rough LOS), but they could be a long way off (like 20 miles or more). That's when a 50 watt radio, with a good antenna comes into play. If all you're looking for is good communication while with a group on a trail, a hand held will usually do the trick, especially if you have a good antenna like a Nagoya NA-771. I've used a Baofeng BF-F8HF hand held for a while and it's plenty of radio to talk simplex on the trail with the other Broncos.
Reactions: Mal and Hkak45
JoergH
Champion II
Apr 21, 2021
1,023
1,731
Joerg
Hallbauer
3682
So in relation to this discussion, I'm going to install my mobile in the Bronco next, and was wondering what dual band antennas (2M/70CM) people are using with good results? I'm thinking about mounting on the tailgate of the Bronco using a mount that connect to the tailgate hinge screws. I know that will distort my transmit pattern a bit, making it a little front heavy. Has anyone had an issue with mounting in that location?
Mal
May 21, 2020
1,148
2,742
Albuquerque NM
0283
I agree with what @JoergH said about the repeaters and the handhelds- Depending on where you are at, 5 watts may not hit the repeater but it would be fine for trail coms with a group. A dedicated, hard mounted antenna on the exterior of the vehicle will be better than the antenna on the HT, certainly if you are using it in a closed car (this doensn't 100% matter as much with the Bronco, but still).
I think you start to get into the sweet spot on a hard mounted mobile between 15 and 25 Watts. I ran the Midland 275 (15 Watt) for a long time and had zero problems with it and hitting repeaters, even when I was using a ghost antenna. I recently switched over to a Radioddity DB-25G (25 Watt) https://www.radioddity.com/collections/business-radios-mobile-radios/products/radioddity-db25gand its better than the Midland powerwise, but not that much better ( I got it for the quad monitoring, and because Im a big nerd and like to play around with this stuff. Im not sure about having all the display up in the vehicle though so I might go back to the midland)
The best change I made to my mobile system however was with the antenna. When I changed over to the Nagoya 7770G https://www.buytwowayradios.com/nagoya-nl-770g-nmo.html?___SID=U , that made a huge difference in both reception and transmission. I can hit two repeaters way farther away than I could with the ghost antenna.
I would start with a good medium powered mobile, and focus on a good antenna. That set-up will do more for you than anything else.
Reactions: JoergH and Hkak45
JoergH
Champion II
Apr 21, 2021
1,023
1,731
Joerg
Hallbauer
3682
@Mal Can you provide a little insight on how/where you mounted your Nagoya antenna?
Reactions: Mal
Mal
May 21, 2020
1,148
2,742
Albuquerque NM
0283
Sure- Im still in my sedan (Shakes fists at Bronco allocation gods) so I didn't do anything crazy. Im using a lip mount centered in the top of the rear decklid. the 7770G is a NMO mount option and the lip mount is the one I got from midland back when I ordered the ghost antenna. The antenna itself is 38 inches, so it puts the top of the antenna at about 6'4" or so. One nice thing about an NMO mount is it is easy to unscrew and stow if clearance becomes an issue or I need to run the car through a car wash or something. For what its worth, a nice quarter-wave antenna would work well too, and it wouldn't be as tall or noticeable as the Nagoya
Whenever the Bronco arrives, I am planning on mounting the Antenna in the rear. I am thinking about fabbing up a plate to ride above the third break-light on the tailgate. That will also give me sort of a ground plane (depending on how big the plate is), but it will be ridiculously high. Someone on here used a wrangler antenna mount bracket that mounted on the retaining bolts on the tire-carrier, but they may have had to do a little work to get it to fit. so there are some options for mounting out back.
I have also seen some nice Cowl-mounts with an NMO connector drilled in and I'm going to look at that too. I just dont want a lot of stuff in my front view if I can help it.
shortbus
Champion III
Aug 15, 2022
8
23
846
McAlester, OK, USA
James
Schulz
6149
I mounted the MXT-275 Head unit under the steering wheel. I drilled a whole on my Ditch light bracket and cleaned up some powder coating and mounted the Ghost Antenna on the mount.
Reactions: Rhiostatic and Mal
