So my fuel sending unit finally diedSo I have two choices one is to drop the tank or cut a access hole to get to the part. I noticed the skid plate has 3 bolts on the fwd side and probably 3 on the back side. I was told that basically hat holds up the tank . I also have a class 3 hitch installed and also wondering if that has to be removed in order for clearance of the tank to be dropped. I also heard removing of the fuel lines could be a pain even with the removal tool. Any ideas or advice would be greatly appreciated. Thanks
