Jun 06, 2020
When I first got my 1979 Bronco back in 1987 it was stock gray color, not original paint. It is the Custom with nothing fancy on it. There is a roll bar behind the front buckets. I tore up the Ford 9 inch rear end twice and the last time I twisted the pinion into. It was lifted 4 inches and 33 tires on it by then. I got tired of fixing it so I put a Dana 60 out of a 1974 F250 we had that was not running. That fixed the rear end and it is still in it today. Now I had 5 hole up front and 8 hole in the back which I didnt want to carry two spares. I had a buddy who had a junk 3/4 ton Chevy and I got the knuckle joints out including the brakes and put it on my Dana 44 front end and problem fixed. As far as the next step I have a set of early Super Duty axles that is going under it that has 4 wheel disks. I do believe I may change it to leaf springs up front also. I just put a 500 HP 460 with tunnel ram on it.
Deano Bronc, montanabroncos
