Final Bronco Order Guide
BuzzyBud
Aug 7, 2020
1,746
7,241
USA
Warren
Parlee
0884
Some weird ass limitations....why does adding full vehicle steel bash plates disqualify headliners, cargo mats etc.... makes no sense
Not sure you are prepared for this, but here goes. Brace yourself!
First the short answer. Ford has purposely built dependencies into the Build and Price application to limit the overall weight of the Bronco you configure so you can load it up with loved ones and gear.
Did that help? I doubt it! So now read on.
Ford has built a superb vehicle that has a class designation. You have heard the marketing phrases such as, “Best in Class”. Being the best in class is important to the Bronco and that limits the total weight. Now as a potential buyer you come along and select a model and options. Both have the potential of adding weight to your Bronco even before you take delivery.
As a case in point, the Badlands and the First Edition models are their most capable Broncos, those models especially have more weight. Keep in mind there are significant differences between the 2-door and the 4-door models, but I will try to avoid getting too deep into the weeds. So, some potential buyers simply change model/door selection to add on more options.
Still with me? Read on!
Another way a buyer can work within the system is to modify the options selected. Before you go down that road, it is helpful to understand what adds significant weight to a Bronco. For that, you have three major categories. I will list them and the estimated weights. Please keep in mind these weights are estimates.
  • Armor: Steel Front Bumper = 90lbs, Rear Steel Bumper = 50lbs, Bash Plates = 50lbs, Rock Rails = 60lbs.
  • Axles/Tires/Suspension upgrades = 100+lbs
  • Engine upgrade = 150lbs
If you change some of your options, you might be able to arrive at a Bronco which is close to your dream vehicle. Some buyers may add/change features once they take delivery.
Hope this helps.
PS – I suspect Ford understands this issue which is fondly referred to as the “GVWR Dilemma” and maybe cooking up a solution for the MY22 Broncos. For me, I will be watching the aftermarket for aluminum armor replacements to reduce weight so I can add in more big dogs!
Glenn
Advocate I
Jun 27, 2020
1
3
30
Vermilion, OH, USA
Glenn
Peterson
Just glad Cyber Orange is still a paint option for the 2021, since it looks like it will take most of the year to get my Bronco. Oh well, my 2011 Fiesta just turned 240K and is still running strong. I can wait as long as Cyber Orange is still there.
May 20, 2020
2,170
4,984
Winona Lake, IN, USA
Dean
Smeltzer
0215
Welcome to Bronco Nation Glenn! Great to have you here.
Yeah, I've heard some grumblings about Cyber Orange possibly going away for MY22, but no official word. Do you have an early reservation?
Reactions: Bronc96
Broncadonk MKG
Advocate III
Dec 23, 2020
187
505
1,115
Manhattan, KS, USA
Mikayla
Gentine
2156
I can't tell if I'm just being dense or if I actually caught an error in the online B&P versus the final order guide here.
This applies to Black Diamond but idk if it's applicable to any other trims.
The preliminary and final Ford order guides (in both Ford's official dealer system and this order guide shared by BN) state that rock rails come standard. On online B&P, the 2-door rock rails are optional at $595.
This certainly won't be the straw that breaks this camel's back for me, as I'm set on the BD either way. But I want to make sure this is an error in B&P before I add an unnecessary $600 to my order next week.
May 20, 2020
2,170
4,984
Dean
Smeltzer
0215
Yes, the rock rails are standard. It's just another mistake in B&P. Hopefully they get all of them cleared up on the next update.
Khayze427
Supporter I
Sep 23, 2020
108
161
1,192
Wayne, PA 19087
Kingdon
Runowicz
1277
Page 31 “AXLE AVAILABILITY” seems to imply that the 4.7 ratio is only available from the factory as part of the Sasquatch Package. On the B&P for Badlands it is listed as a no cost option?
TorgSurv
Champion II
Jul 13, 2020
814
2,424
Moab, Ut
Blake
Torgersen
185
That chart is a little confusing, but 4.7 is standard for Badlands with a manual transmission. If you add the auto transmission you get 4.46, unless you also add Sasquatch in which case it goes back to 4.7.
Khayze427
Supporter I
Sep 23, 2020
108
161
1,192
Wayne, PA 19087
Kingdon
Runowicz
1277
Yeah. I’m thinking the Ordering Guide is probably more up to date than the B&P. Thanks.
Reactions: TorgSurv
bpurtz
Advocate I
Jan 11, 2021
4
10
30
Oregon
Bryce
Purtzer
I think the GVWR issue and limits are primarily because of the CAFE standards put in place by Obama. When you increase the weight of a vehicle, you decrease the fuel economy. I suspect Ford needs to maintain a CAFE standard based on the existing GVWR for the vehicles that have accessory limitations.
CCDetroit
Supporter I
Dec 17, 2020
102
222
1,192
Detroit, MI, USA
Carly
Cummings
100003
Has anyone heard any details about the all black interior on the FE? Any description other than all black? If staff or anyone can ask Ford the following, or knows the answer, it would be great!!
1. Will we see the actual interior before March 19?
2. Will there be CGI renderings soon?
3. Will we see the option in B&P on the 20th or in other updates?
4. The vinyl mentioned, is it MGV?
GettyUp
Champion III
Aug 16, 2020
25
42
846
Rancho Cucamonga CA
Rocky
Reynolds
1207
I sure that the has been asked or addressed but can't find it. I have reserved a 2 door but after seeing the interior what to build a 4door can I do this??
JRHopp
Advocate III
Oct 7, 2020
98
194
337
Peoria, IL, USA
Jacob
Hopping
Are the Pod Lights listed? I can’t find them — of course my eyes are not as sharp as the use to be.
Ah-Ha! Found them. Searched the Excel list. Thank you. “BRONCO MIRROR MOUNTED OFF-ROAD LIGHT KIT”.
Now the question is — pre-installed at factory or dealer installed?
Where did your dealer find these? I'd like to have these factory installed? These and the Amber under body off road lights
Thanks!
Reactions: CCDetroit
Khayze427
Supporter I
Sep 23, 2020
108
161
1,192
Wayne, PA 19087
Kingdon
Runowicz
1277
