Jul 09, 2020
Bronc95Jul 09, 2020
paul rondelliJul 09, 2020
Bronc95Jul 09, 2020
Tack HammerJul 09, 2020
Jernst8854Jul 12, 2020
FSBdenverJul 13, 2020
V8_PowerJul 14, 2020
Bronc95Jul 14, 2020
It is a shame since I just got the vehicle... owner said he did in fact change it but he may have changed another one. Who knows.Sounds like a wiring issue, if a gauge reads full that means there is no resistance. I believe this is a one wire circuit so that probably isn’t shorted. Pull put the instrument cluster and look at the wire traces on the back, something might have burned up. Also are you sure he replaced the right sensor? Mine is a 351 not a 302 so I’m not positive if yours is the same but mine has two coolant temp sensors, one for the pcm to read and one for the dash
paul rondelliJul 15, 2020
RedneckBroncoJul 25, 2020
