Elite Series Fog Lights | Diode Dynamics
Diode Dynamics
Apr 06, 2022
Factory fog lights are built to meet minimum output requirements. Every aftermarket design available provides similar lackluster performance, but with an LED. The focus has been on LED appearance, not increased output. There has never been an aftermarket fog light designed from the ground up for performance - until now.
Diode Dynamics is excited to introduce our Elite Series Fog Lamps!
The first OE-style fog lights that were designed for true performance. With a custom-engineered patent-pending optic, multi-die automotive emitters, and high-power full-copper circuit boards, the Elite Series fog light delivers up to 5 times more output than halogen lamps. With a plug-and-play installation, this is one of the easiest and most effective upgrades you can make to improve your visibility in inclement weather.
Output that Outperforms. The Elite Series Fog Lamp is built around a highly-engineered single-piece PMMA lens. This optic was carefully designed using advanced optical simulation software to produce a light pattern that is wider than any other aftermarket fog lamp on the market, with an 80-degree spread of highly intense light. Even with this extremely wide band of light, the pattern is extremely smooth throughout, with an extremely sharp cutoff to avoid glare to other drivers, including a BMW-style “color flicker” at the very edge of the pattern. Diode Dynamics engineers accomplished all this while still meeting SAE F3 fog light standards, for legal on-road use. Please check your local laws and regulations for aiming, installation, and applicability.
White or Yellow. All Elite Series Fog Lamps are available in a cool white or selective yellow output color.
The white is a 6000K color temperature, which is a true cool white output. This will perfectly match other LEDs on your vehicle, such as DRLs or running lights. The white option also offers a premium BMW-style color band at the very top of the beam pattern.
The selective yellow option is 3000K in color temperature, which is great for high contrast in inclement weather, or in providing a distinctive look on the road. The yellow lamp consists of a yellow multi-die LED emitter paired with a yellow-tinted lens, to provide unmatched output and optical efficiency, even with the intense yellow output.
Backlight Functionality. All Elite Series Fog Lamps come standard with an integrated amber accent light. This backlight feature fully illuminates the main lens with amber LEDs, intended to match other position, sidemarker, or corner lights on your vehicle. This feature can be wired to any constant 12-volt source for your desired vehicle function, using the included tap connector. It will shut off automatically if the main beam is activated. Check local laws and regulations for acceptable use.
Bolt-On Fitment. Elite Series Fog Lamps can be installed on most vehicles in minutes. Simply remove your factory fog light assembly and ours will bolt right in its place, using sturdy glass-fiber-reinforced brackets. With built-in adjustment, the lamps can be aimed after installation. To wire them up, a pair of waterproof plug-and-play adapters are included to connect the lights to your factory bulb sockets.
In the Box:
  • Two (2) Elite Series Type A fog lamps
  • Two (2) H11 4-pin DT backlight tap wires
  • Two (2) T-taps
  • Mounting guide
Note: This kit is a replacement for OEM fog lamps. If your vehicle does not have fog lamps, additional hardware and wiring may be needed for installation.
Click HERE to shop Elite Series Fog Lamps for the 2021 Ford Bronco (Standard Plastic Bumper)!
Proven Reliability - Backed for 8 Years. Like our popular Stage Series lineup, Elite Series LED lamps have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components on your vehicle. With integrated moisture-proof vents, the lamps can “breath” with changes in temperature, maintaining a strong seal over time. And with built-in circuit protection for voltage spikes and reverse polarity, these lights will keep working for years. They are backed by an industry-leading 8 year limited warranty.
Assembled with Quality - in the USA. Elite Series Fog Lamps are assembled in the USA using OEM-grade materials, including a precision aluminum casting, UV-coated outer lens, copper-core circuit board, and multi-die automotive emitters. After being assembled by Diode Dynamics in St. Louis, Missouri, they are robotically sealed with urethane epoxy for long-lasting protection against moisture, and packaged in form-fit foam for safe transportation. No expense has been spared, from materials to assembly, right here in America.
If you have any questions, please don't hesitate to post, direct message, or email [email protected].
Note: All US forum members are eligible for a FREE shipping code! Just send us a direct message.
John C.
Diode Dynamics
Diode Dynamics
Follow Us: FB // IG // YT // TikTok
the poacher, Ditchrunner
Any idea when the OE harness will ship if I ordered the stage fog kit for my modular bumper? I took delivery of the kit and the OE harness to plug the fogs into the factory harness was supposed to be shipped separately when ready.
LOL, mine has been on for months and it still hasn't arrived
Bronco Nation 278
IndianaBroncos on Facebook​
srick76
Yea, I got mine in January and still waiting. Thank god I was able to install them without it.
Michael Grasso
Hello there!
Our team has not received them yet. Our latest backorder notice was dispatched by our customer service team via email on 1/28.
This included an alternative solution until' the specific wiring harness is available and shipped directly to you.
If you haven't received this email, please go ahead and give us a call at 314-205-3033 Monday-Friday 10 a.m.- 5 p.m. CST, or shoot us an email at [email protected], and our service team would be more than happy to help you with your specific order!
John C.
Diode Dynamics
Diode Dynamics
Michael Grasso, srick76
Apr 06, 2022
Anything for the "Capable" Bumper?
Great question!
We've had many users ask this question regarding our Elite Series Fog Lamps and SS3 LED fog light kit.
Our engineering team has been informed but we're currently waiting for more fitment information to become available.
We hope to offer an option for the 2022 Bronco Capable bumper in the future. However, we don't have anything confirmed at this time.
John C.
Diode Dynamics
Diode Dynamics
ChadN
Apr 06, 2022
Great question!
John C.
Diode Dynamics
Thanks! I'm sure you guys will figure the lights out well before Ford figures out how to build my Bronco! :-(
If you've pre-ordered Elite Series Fog Lamps, they'll begin shipping on June 17th!
Diode Dynamics
mmmm January, you guys know it's June right?.....
LOLOLOL
Bronco Nation 278
LOLOLOL
The discussion above regarding January is about our Stage Series Fog Pocket Kit for the modular bumper. NOT our Elite Series Fog Lamps.
The OE-harness mentioned above for the Fog Pocket Kit is available. You should have an update from our customer service team. If you haven't, please go ahead and give us a call at 314-205-3033 Monday-Friday 10 a.m.- 5 p.m. CST, or shoot us an email at [email protected], and our service team would be happy to help you with that.
Our shipping date for June 17th mentioned above is for our recently released pre-order product known as Elite Series Fog Lamps for the standard plastic bumper.
Diode Dynamics
Is the Stage Series Fog Pocket kit in amber, ready to ship, or what is the wait list?
Great question!
https://www.diodedynamics.com/stage-series-fog-pocket-kit-for-2021-ford-bronco-w-steel-bumper.html
Our Fog Pocket Kit is offered in two configurations on our website and is a on 3-4 week backorder in all power levels.
It's important to note, that both options include our amber backlighting if you go with the all-white kit or kit with a 3000K selective yellow set of SS3 LED pods.
You can check the status of products anytime. There will be a notation on listing configurations of the quantity in stock or back-order wait time.
Diode Dynamics
Our production team has begun assembling, packaging, and shipping pre-orders!
Have any questions? We're here to help!
Plus, all US forum members are eligible for free US shipping. Just send us a direct message for the code.
Diode Dynamics
Our July 4th Sale starts NOW! Today through Friday, 7/8/2022, save 15% on all LED upgrades by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive free US shipping.
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes.
Diode Dynamics
THE CLOCK IS TICKING!
Hurry! There are ONLY 3 DAYS LEFT to save on your favorite LED lighting products from Diode Dynamics.
Click HERE to shop!
John C.
Diode Dynamics
Diode Dynamics
ALERT: LAST CHANCE TO SAVE 15% OFF!!!
COUPON CODE:
JULY4
Plus, all orders over $300 will receive free US shipping!
Don’t wait...this sale ends TONIGHT!
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2021. Cannot be combined with other coupon codes.​
Diode Dynamics
COUPON CODE:
JULY4
Click HERE to Shop!
John C.
Diode Dynamics
Diode Dynamics
As many members know, the lighting industry as a whole is still facing many challenges due to current market conditions.
All the more reason to give a HUGE shoutout to our production and supply team who are quite literally on a RECORD pace of output this year!
CLICK HERE TO SHOP
Diode Dynamics
Adventure Day
Jul 20, 2022
@Laura Is it possible to consolidate all of Diode Dynamics posts into a single thread? They spam the same messages to multiple threads over and over.
