DIY Baja Design S1 Lights
jaypiche
Oct 17, 2021
Photos of Baja Designs S1 Lights build.
Bought aluminum at Home Depot, then made a bracket for the lights.
Wired them to the purple wire at the front of the engine bay. Then to give it power, wired the purple to the yellow (Aux 6). Referred to the Aux lights wiring diagram from Ford. Re-wired the S1 lights so that I could retro fit it to the current wiring solution. Cut the switch, cut the relay, then combine power and grounds together with butt connectors. Lots of place to tie down the wiring, and easy to get it to the lights near the front 3/4 panel. Will add more photos in comments.
Deano Bronc, Bschurr
kimmnen, Deano Bronc
Oct 17, 2021
Nice job @jaypiche
May I suggest you hit that flat stock with some black spray paint…
jaypiche, Deano Bronc
