Actually its a technique you use when off-roading, specifically when climbing or descending, and say you stop and stall the truck on a climb, a failed hill climb in other words, with the engine off, engage reverse, and you can crank in gear while letting off the brake slightly to get the truck moving in reverse in a controlled manner.
You never touch the clutch. Nor risk being in neutral while engaging a gear and rolling back.. things happen fast in those situations.
works the same way descending forward.. stall the truck and restart in gear without the clutch. Allows you to 2 foot the truck in a controlled manner.
Its a pretty handy technique for a manual transmission
edit: Most modern cars/trucks require you to have the clutch in to start as a safety feature.. there may be a button to enable it but the jeep doesn't have one so I am thinking the bronco won't either.
http://www.ukoffroad.com/tech/climbing.html
Stalled engine descent (PRACTISE THIS ON A TAME HILL FIRST).
As soon as the engine stalls, or is about to, press the brake pedal firmly to hold the vehicle - press the brake FIRST not the clutch.
Depress the clutch and select low reverse gear.
Release the clutch pedal.
Check your steering is straight and quickly view the route back down.
Slowly release the footbrake - the vehicle should remain stationary on the engine compression.
Start the engine whilst holding the steering wheel firmly with one hand - we don't normally start the engine in gear, but in this case, it is in the interest of maintaining traction and control. Be prepared for the vehicle to jolt as the engine starts and then allow the vehicle to descend without resort to touchng the accelerator. If the vehicle begins to slide or lose traction, just briefly and gently press the accelerator sufficiently to match the wheel and ground speed to regain control again.
Running engine descent (PRACTISE THIS ON A TAME HILL FIRST).
Just before the vehicle completely loses traction press the brake and clutch pedals together and select low reverse gear.
Hold the vehicle on the brake pedal and slowly release the clutch until almost engaged then release brake and clutch together gently.
Allow the vehicle to descend without resort to touchng the accelerator, unless the vehicle begins to slide or lose traction - in that event just briefly and gently press the accelerator sufficiently to match the wheel and ground speed to gain control again. You should resist the temptation to brake as this can cause the vehicle to slide sideways and you can then get very quickly into a rollover situation.
Beware wet clay as it clogs tread. This Land Rover can go no futher, despite having mud terrain tyres.
It was easier to walk without shoes also.
