I was wondering if anyone knows if you could can hard wire this kit into the bronco? Was thinking of picking it up with my ford points.and also purchasing a bracket that mounts it in the hidden trunk compartment.
Burrito Connoisseur
RagnarKon
August 28, 2021
2445
5820
4080
105201
Aug 16, 2022
You absolutely can.
Obviously may need to buy some extra wiring depending on where you want to install it.
thanks i kinda figured it could be done , would just have to replace the big alligator clips with more heavy gauge wire and possibly fuse unless i can use the one that’s attached. i wasn’t sure if there was anything different about this pump compared to the regular one , other than the alligator clips to hook to a battery
