In high package, I didn’t get the USB Ports in the dash. I hate having the cable run up the front of the screen to power go pros…
Looked at a few ways to do it, but never followed through. Has anyone found a clean, permanent solution?
I hard wired a 12v USB converter to the fuse panel under the steering wheel, mounted it with dual lock onto the back of the support panel and ran a lightning charging cable through the seam in the dash panel to power my iPhone while in a dash mounted holder.
You could use this concept and run the power cable to the left side under the dash and then up by the A pillar and then across the front of the lower portion of the windshield to power your GoPro
I believe this is what it is for, but could be tough to get access to the top of your dash without removing it. I don't have mine yet so I don't know if there is a different location on the top of the dash that would be accessible. https://www.buckyourbronco.com/shop/p/good-ole-cigarette-receiver-8kwhj @Charlie is the seller so he might have some insight.
That would be super clean, and there are several spots on the dash tempting to drill into!
Jakob1972
August 17, 2020
4940
11361
4080
1100
Jun 20, 2022
Since I hate cables and even if I had a USB port on the dash I would not find a cable that would be the perfect size. I am going to use this. I used these on my Kayak when I added some lights and a depth/fish finder. I can pull out just enough cable as I need to make the connections. run it under the dash then hard wire it in.
