Great job & nice video too!
May I make a pair of suggestions that will eliminate some potential issues down the road:
1 - Use waterproof connections (not T-taps) to connect the 3 individual lights to your wiring harness
2 - Add a 2 wire waterproof connector for the power and ground wires at the end of your harness and run them over by the camera & wiper connectors so all the connections are in the same place. This will allow you to easily disconnect the Raptor light harness when you need to remove the grille in the future.
Keep up the great work
@Bronc84
