Jul 02, 2022
I have logged my MPG for almost 10,000 miles now calculating mileage on Fulley.com, which translates to 41 tanks of gas in my 2-door Big Bend. I travel and work from the road towing a small 1500 lb camper. I had used nothing but 93 octane up until June 23 when I decided to compare mileage and power with a switch to 87 octane for a few tanks. Below is a chart showing the comparison between 87/93 over seven tanks of gas each. Again, this is towing a 1500 lb camper across the midwest and east coast.
I don't run the Bronco hard, rarely exceeding 3,000 rpm, set the cruise on the speed limit and tow in 5th gear at highway speeds (2,500 rpm at 70 mph). I found I get better MPG this way as it stays out of the turbo. If you tow in 6th it will still pull the speeds but it has to ramp up the boost. As you can see, I've had minimal impact on my MPG and I have had no discernible loss of power. In other words, I can't tell the difference between 87 and 93 octane when I'm towing, it feels the same either way and pulls the hills in the Appalachians the same way at the same speed. I'm not hearing any detonation and the operating temperatures remain the same.
Make of this what you will but for me I'm running 87 octane from here on out.
Crawler Green, Deano Bronc
