2021 Ford Bronco Technical Specs: Horsepower and Torque
Giggles
Super Supporter II
Mar 21, 2021
30
90
281
Arcadia, Phoenix, AZ, USA
Bryan
Neff
2560
Just a note for those thinking to just throw in a fill up of high octane when wanting a power boost, it usually takes about 2 tanks worth for the octane detection to adjust to the higher octane
Oh, that's good to know. I thought just a fresh tank of higher octane would do it.
Deepshag
Jul 13, 2020
423
1,088
1,713
Caliunicornia
Shag
Hughes
Interesting. Where can I find more info about this? I don't see anything online. My thought would be as soon as the gas runs the line the engine will be burning a higher octane gas. Are you saying the engine self tunes to the gas?
Norderwurm
Supporter I
Apr 11, 2021
139
402
1,605
O'Fallon MO
Matthew
Barker
2961
The engine advances or retards the timing by detecting pre-ignition, or knock. It's not reading or analyzing the fuel itself. So think of the logic path in the ECU. It sparks a cylinder, was thee pre- ignition? No? Then advance the timing a bit. But it's not doing this on every fire, and the adjustment is small, to keep you from damaging the engine. So it has to work it's way up to the higher octane. The only time you would see a big jump in timing is if you want from high octane to low octane, because then you'll get a knock, and the ECU will jump back to keep from possibly damaging the engine. There is a line in the code to turn octane adjustment on or off. It's fine to have it turned off when running a stock tune for 87 octane. I think here we have Ford tuning the Bronco up with the Ford performance tune.
From https://www.mustangecoboost.net/threads/which-performance-tune-should-i-use.15809/
This from a Ford engineer:
Reactions: Giggles
Deepshag
Jul 13, 2020
423
1,088
1,713
Caliunicornia
Shag
Hughes
Cool stuff thanks -
