May 21, 2020
Soon to be Big Bear, CA resident, north of airport. Moving from North Hollywood.
'75 Bronco called Mr. Toad's Wild Ride (after the crazy Disneyland ride).
*351W, Truck Avenger carb, Weiand Stealth intake, WH JBA ceramic shorties, custom 2 to 1 exhaust, Flowmaster 40.
*Strengthened C4 with improved cooling, Dana 20, JB twin stick, WH HD driveshafts.
*Dana 44, Yukon 32 spline axles, Detroit locker, rock protection, custom chromoly bent long radius arms with heims.
*Ford 9", HD shaved housing with rotated spring perches and rock protection, Currie 32 spline axles, Detroit locker, rear driveshaft rock protector.
*3.5" WH progressive coils, 14" Bilstein 7150 with custom mounts.
*5.5" BCB thick leaf springs, Bilstein 12" 5150 with Duff mounts, custom +1" lengthened spring shackles.
*GM tie rod over conversion, HD tie rod, HD drag link, HD track bar, custom track bar riser, custom track bar drop bracket.
*Rebuilt power steering box, upgraded steering shaft.
*Hydroboost conversion, slotted and dimpled front disc brakes, rear Explorer disc brakes.
*200 amp alternator, AGM battery, rear battery box.
*Duraspark II ignition.
*Custom trailer mount winch bumper (winch can be on front or back bumper) with 3 offroad lights.
*Custom rear bumper, holds tire, 5gal water, 5gal gas, cooler, shovel, axe and Hi Lift jack.
*Custom rocker protection tied to frame.
*Custom tube doors with removeable clear panels and windows.
*Custom family roll cage, tied to frame, also tied to body on B and C pillars, grab bars all around, floor plates for front and rear seats and belts, locking storage under passenger seat, tank map light, airplane LED lights, CB speaker, flashlight holder.
*Custom locking rear tool box behind seat.
*35" Pro Comp tires.
*Rampage soft top.
*PRP daily driver seats, Crow racing harnesses.
*BCB triple pass radiator and Taurus aux fan, Derale trans cooler and fan, Hayes power steering cooler and fan.
*Tuffy glove box and center console.
*B&M modified racing shifter and custom mount, golf cart cup holders.
*Pioneer HD radio and amps, Infinity Kappa speakers.
*Handheld radio adapted to use antenna.
*NASCAR brake cooler fans mounted on grab bar for passenger cooling.
*Custom LED rock and interior lights.
*Custom fire extinguisher mount.
*Convex side mirrors, large convex Longacre rear mirror.
*WH wiper motor conversion.
*Custom LED headlights.
*2 Stebel horns plus another horn.
*Rampage soft top.
