First off apologizes for the typo in the thread title(seems you can’t edit those once they’re in the world).
Anyone else’s front wheels on the 22 bronco sport covered in brake dust from normal driving? Rear wheels stay clean it’s almost like all the vehicle braking is done with the front wheels. I am seeing if driving with the activtrac turned off makes a difference but that is a pain as I have to navigate down into the menu every-time I start the car to turn it off before I start driving. No physical button I have found on the Big Bend. For reference the photo shows the car just washed a week ago.
Is the other side just as bad? If both are the same, then I would be surprised it is a caliper issue. Rare that you would have both front calipers freeze up at the same time.
I would take it back to the dealer and have them check the entire braking system.
Although I have seen some that seem to charge every stoplight or stop sign which will wear out the front brakes pretty quickly.
